Brand
StarTech.com 10m CL2 Active HDMI Cable - 4K
Quicklinx: DBCRWS00 Mfr#: HD2MM10MA
Length: 10m
Select:
14 in stock
£76.62 ex VAT
£91.94 inc VAT
The cable's built-in amplifier circuitry actively boosts the HDMI signal with no external power required. It supports longer connections than regular HDMI. The active cable also features a thinner wire construction for more flexibility, making it ideal for in-wall installations.
This 4K HDMI cable supports resolutions of up to 4K@60Hz (3840 x 2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
  • Create 4K HDMI connections over longer distances
  • Experience the best that HDMI has to offer
StarTech.com 10m(30ft) HDMI 2.0 Cable, 4K 60Hz Active HDMI Cable, CL2 Rated for In Wall Installation, Long Durable High Speed Ultra-HD HDMI Cable, HDR 10, 18Gbps, Male to Male Cord, Black - Al-Mylar EMI Shielding (HD2MM10MA) - HDMI cable - 10 m
Cable
HDMI cable
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
P/N: ADJPROJCART, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWHANGER, FPWTLTBAT, FPWTLTPORT, MBLTVSTNDEC, ST122HD202, ST124HD202, STNDMTV100, STNDMTV70, STNDMTVDUO
Cable Type
HDMI cable 4K support
Length
10 m
CL2 rated jacket, HDR support, built-in amplifier
Connector
19 pin HDMI Type A - male
DBCR StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £76.62
DBCR StarTech.com 15m CL2 Active HDMI Cable - 4K In Stock £104.15
Length: 10m
Stock Status: In stock
