StarTech.com 10m CAT6a Ethernet Cable LSZH - White
Quicklinx: H15HWS00 Mfr#: NLWH-10M-CAT6A-PATCH
Length: 10m
Colour: White
10 In Stock
£37.87 ex VAT
£45.44 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 10m - White - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Reliable high-speed performance
    This CAT6a Ethernet cable supports data transmission speeds of up to 10 Gbps, ensuring smooth and efficient networking for various devices.
  • Enhanced shielding for clear signals
    The S/FTP design minimizes Noise and EMI/RFI interference, ensuring a stable and efficient data connection.
  • Safe and environmentally friendly
    The Low Smoke Zero Halogen (LSZH) jacket makes this cable a safer choice for installations in sensitive areas, reducing the release of harmful substances in the event of a fire.
  • Durability through thoughtful design
    Molded strain reliefs and snagless RJ-45 connectors enhance the cable’s durability, reducing the likelihood of damage during use.
  • Compliance with industry standards
    Meets various compliance standards including RoHS, ETL, and ANSI/TIA-568.2-D, assuring compatibility and quality in networking applications.
StarTech.com 10m CAT6a Ethernet Cable - White - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 10 m - white
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
340.3 g
White
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
31 cm
Shipping Depth
22 cm
Shipping Height
4.5 cm
Shipping Weight
357.4 g
Length: 10m
Colour: White
