StarTech.com 10m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H155WS00 Mfr#: NLBL-10M-CAT6A-PATCH
Length: 10m
Colour: Blue
10 In Stock
£11.95 ex VAT
£14.34 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 10m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Efficient data transfer
    This cable supports data rates of up to 10 Gbps, ensuring fast connections for demanding applications.
  • Durable construction
    Designed with strain reliefs and foil shielding material, this cable provides durability while protecting against physical damage.
  • Safe materials
    The Low Smoke Zero Halogen (LSZH) jacket minimizes emissions, making it suitable for use in safety-critical environments.
  • Enhanced interference protection
    With minimized Near-End Crosstalk (NEXT) and EMI/RFI protection, the cable safeguards signal clarity and integrity.
  • Reliable compatibility
    Compliant with various standards including IEEE 802.3bt and PoE++, this patch cable is compatible with a range of networking devices.
StarTech.com 10m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 10 m - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
340.3 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
31 cm
Shipping Depth
22 cm
Shipping Height
4.5 cm
Shipping Weight
357.4 g
Length: 10m
Colour: Blue
