StarTech.com 10m CAT6a Ethernet Cable LSZH - Aqua
Quicklinx: H14HWS00 Mfr#: NLAQ-10M-CAT6A-PATCH
Length: 10m
Colour: Aqua
£38.11 ex VAT
£45.73 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 10m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Reliable performance
    This patch cable supports data transfer speeds of up to 10 Gbps, making it suitable for high-demand network environments.
  • Safe materials
    Constructed with Low Smoke Zero Halogen (LSZH) materials to ensure lower smoke emissions when exposed to fire, enhancing safety in enclosed spaces.
  • Advanced shielding
    Utilizes S/FTP technology to reduce Near-End Crosstalk (NEXT) and provides EMI/RFI protection for a clearer signal.
  • Strain relief design
    Incorporates strain relief features to prevent cable damage during installation and everyday use.
  • Power efficiency
    Capable of carrying up to 100 W of power, this cable is optimized for PoE++ applications, supporting devices that require high power levels.
StarTech.com 10m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 10 m - aqua
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Aqua
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
340.3 g
Aqua
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
31 cm
Shipping Depth
22 cm
Shipping Height
4.5 cm
Shipping Weight
357.4 g
Length: 10m
Colour: Aqua
