StarTech.com 10m CAT6a Ethernet Cable - Grey - CAT6a STP Cable - Snagless
Quicklinx: FLWJWS00 Mfr#: 6ASPAT10MGR
Length: 10m
Colour: Grey
£44.60 ex VAT
£53.52 inc VAT
This CAT6a Ethernet cable meets all Category 6a cable specifications. It ensures reliable 10Gb connections between your network devices.
Tested for up to 500MHz frequency, each CAT6a cable is more than suitable for 10GBase-T Ethernet networks.
Built for quality performance, the cable features 100% copper and foil-shielded, twisted-pair wiring. The cable is designed to keep the data signals traveling through your network free from noise and interference. It's perfect in environments that are prone to large amounts of electromagnetic interference (EMI/RFI).
This CAT6a patch cable is built using 100% copper wire and is tested to comply with ANSI/TIA 568 C.2 Category 6a requirements. StarTech.com doesn't use copper-clad aluminum (CCA) wire which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6a Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
StarTech.com 10m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT10MGR) - patch cable - 10 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH - up to 500 MHz
FLWJ StarTech.com 10m CAT6a Ethernet Cable - Black - CAT6a STP Cable - Snagles In Stock £44.60
FLWJ StarTech.com 10m CAT6a Ethernet Cable - Aqua - CAT6a STP Cable - Snagless In Stock £44.60
FLWJ StarTech.com 10m CAT6a Ethernet Cable - Blue - CAT6a STP Cable - Snagless In Stock £44.60
Length: 10m
Colour: Grey
