This CAT6a Ethernet cable meets all Category 6a cable specifications. It ensures reliable 10Gb connections between your network devices.
Tested for up to 500MHz frequency, each CAT6a cable is more than suitable for 10GBase-T Ethernet networks.
Built for quality performance, the cable features 100% copper and foil-shielded, twisted-pair wiring. The cable is designed to keep the data signals traveling through your network free from noise and interference. It's perfect in environments that are prone to large amounts of electromagnetic interference (EMI/RFI).
This CAT6a patch cable is built using 100% copper wire and is tested to comply with ANSI/TIA 568 C.2 Category 6a requirements. StarTech.com doesn't use copper-clad aluminum (CCA) wire which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6a Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
Reliable Shielding
The aluminum-polyester foil shielding in this cable minimizes the risk of interference, ensuring stable and uninterrupted data transmission. -
PoE Ready
This cable is compatible with Power over Ethernet, allowing devices to receive power and data through the same connection. -
High-Quality Connectors
Equipped with gold-plated RJ-45 connectors, this cable provides excellent conductivity and minimizes signal loss. -
Durable Construction
The PVC jacket and molded connectors offer durability and protection, making this cable suitable for both home and office use. -
Snagless Design
The snagless feature prevents tangling and damage during installation, ensuring a hassle-free setup.
 - StarTech.com 10m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT10MBL) - patch cable - 10 m - blue
 - Patch cable - CAT 6a
- Technology
 - Shielded twisted pair (STP)
- Shielding Material
 - Aluminium-polyester foil
- Wires per Cable
 - 8 wires
 - Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
- Length
 - 10 m
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - Blue
 - Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
 - PVC
- American Wire Gauge (AWG)
 - 25
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
- Length
 - 10 m
 - Blue
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - RoHS, REACH - up to 500 MHz
