StarTech.com 10m CAT6a Ethernet Cable - Black - CAT6a STP Cable - Snagles
Quicklinx: FLWGWS00 Mfr#: 6ASPAT10MBK
Length: 10m
Colour: Black
10 In Stock
£40.56 ex VAT
£48.67 inc VAT
This CAT6a Ethernet cable meets all Category 6a cable specifications. It ensures reliable 10Gb connections between your network devices.
Tested for up to 500MHz frequency, each CAT6a cable is more than suitable for 10GBase-T Ethernet networks.
Built for quality performance, the cable features 100% copper and foil-shielded, twisted-pair wiring. The cable is designed to keep the data signals traveling through your network free from noise and interference. It's perfect in environments that are prone to large amounts of electromagnetic interference (EMI/RFI).
This CAT6a patch cable is built using 100% copper wire and is tested to comply with ANSI/TIA 568 C.2 Category 6a requirements. StarTech.com doesn't use copper-clad aluminum (CCA) wire which is subject to problems like weak power delivery, heat buildup, equipment damage and possibly fire.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The CAT6a Ethernet cable also features molded boots which offer strain relief by stopping the RJ45 connectors from bending at sharp angles. This reduces the risk of cable damage, which could decrease network connectivity and performance.
  • Reliable Performance
    This Ethernet cable supports a tested frequency of up to 500 MHz, ensuring efficiency in high-speed data transmission for demanding applications.
  • Durable Construction
    The cable features a PVC jacket and molded design that enhances sturdiness and prevents snagging, making it suitable for both home and office settings.
  • Effective Shielding
    With aluminum-polyester foil shielding, this cable effectively guards against RFI and EMI, promoting clearer communication in environments with electronic interference.
  • Strain Relief Feature
    Designed with strain relief, this cable minimizes pressure on the connectors, extending its lifespan and ensuring reliable connections over time.
  • Versatile Compatibility
    The CAT6A Ethernet cable is PoE ready, allowing it to deliver power alongside data for compatible devices, providing convenience and efficiency.
StarTech.com 10m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT10MBK) - patch cable - 10 m - black
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
10 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
10 m
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH - up to 500 MHz
FLWG StarTech.com 10m CAT6a Ethernet Cable - Aqua - CAT6a STP Cable - Snagless In Stock £40.84
FLWG StarTech.com 10m CAT6a Ethernet Cable - Grey - CAT6a STP Cable - Snagless In Stock £40.84
Length: 10m
Colour: Black
