StarTech.com 10m 10G SFP+ Active DAC Cable
Quicklinx: D9VCWS00 Mfr#: SFP10GAC10M
Length: 10m
Colour: Black
Select:
13 In Stock
£113.91 ex VAT
£136.69 inc VAT
Connect your MSA compliant 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
StarTech.com MSA Uncoded Compatible 10m 10G SFP+ to SFP+ Direct Attach Breakout Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Active Transceiver Module DAC, 10GE SFP+ Breakout Cable - Lifetime Warranty (SFP10GAC10M) - 10GBase direct attach cable - 10 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Active cable
Length
10 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
10 m
520 g
Connector
SFP+ - latched
SFP+ - latched
FCC, RoHS, MSA
70 °C
D9VC StarTech.com 10m 10G SFP+ Active DAC Cable In Stock £113.91
Length: 10m
Colour: Black
