StarTech.com 10m 10G SFP+ Active DAC Cable
Quicklinx: D9VNWS00 Mfr#: SFPH10GACU10
Length: 10m
Colour: Black
Hurry, only 3 left in stock!
£108.69 ex VAT
£130.42 inc VAT
Connect your Cisco 10GbE SFP+ network devices with this cost-effective, active Twinax copper cable. This 10G SFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
The active twinaxial cable is a fully hot-pluggable solution, supporting 10 Gigabit Ethernet applications connected through SFP+ (Small Form-Factor Pluggable) ports.
Designed for high-speed interconnects, this cable is intended for medium-distance applications such as across-rack network switch or server connections.
  • Efficient connectivity
    This cable features SFP+ connectors on both ends which provide a secure and efficient connection for high-speed data transfer.
  • Reliable design
    The latched design of both connectors ensures a stable connection that minimizes the likelihood of accidental disconnections.
  • Flexible installation
    With a length of 10 meters, this cable allows for flexible positioning and installation within network setups.
  • Environmental compatibility
    Operating effectively in temperatures between 0°C and 70°C, this cable is suited for a variety of environments.
  • Compliance assurance
    Meeting the necessary FCC, RoHS, and MSA standards, this cable assures dependable performance in professional settings.
StarTech.com Cisco SFP-H10GB-ACU10M Compatible 10m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10Gbps Low Power Active Transceiver Module DAC Cable, Firepower ASR9000 - Lifetime Warranty (SFPH10GACU10) - 10GBase direct attach cable - 10 m - black
10GBase direct attach cable - SFF-8431/SFF-8432
Twinaxial
Active cable
Length
10 m
Connector
SFP+ - latched
Connector (Second End)
SFP+ - latched
Network Cable Type
Twinaxial
Jacket Material
PVC
American Wire Gauge (AWG)
24
Impedance
100 Ohm
Active cable
Length
10 m
520 g
Connector
SFP+ - latched
SFP+ - latched
FCC, RoHS, MSA
70 °C
D9VN StarTech.com 10m 10G SFP+ Active DAC Cable In Stock £108.69
Length: 10m
Colour: Black
