Deliver fast, reliable, data transfers, safely over high end networking equipment. The A50FBLCLC10 10m 850nm Laser-Optimized Multimode Fiber (LOMMF) Aqua Cord features 50/125 micron fiber for high-speed, high bandwidth data transmissions over 10 Gigabit Ethernet and Fiber Channel networks - the perfect solution for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM3) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
High compatibility
Designed to seamlessly integrate with PC systems, this fiber optic cable ensures a reliable connection for all your networking needs. -
Enhanced durability
Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable is built for both safety and longevity, reducing the risk of smoke and toxic materials in case of fire. -
High performance
With a core and cladding diameter of 50 / 125 micron, this duplex cable supports 100G networks, ensuring high-speed data transmission for demanding applications. -
Efficient connectivity
Equipped with LC multi-mode connectors on both ends, this cable offers a secure and stable connection, minimizing insertion loss to less than 0.3dB for optimal signal integrity.
- StarTech.com 10m (30ft) LC/UPC to LC/UPC OM3 Multimode Fiber Optic Cable, Full Duplex 50/125µm Zipcord Fiber Cable, 100G Networks, LOMMF/VCSEL, <0.3dB Low Insertion Loss - LSZH Fiber Patch Cord - patch cable - 10 m - aqua
- Patch cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 10 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Designed For
- P/N: 455883B21ST, EXSFP10GESRS, J9150AST, J9152AST, MASFP10GBSR, SFP10GBLRMST, SFP10GBSRST, SFP10GLRMST, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, SV565FXHD4KU
- Network Cable Type
- Patch cable
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 10 m
- Aqua
- Connector
- RoHS
- Designed For
StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.24 |
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £20.64 |
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £32.44 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £23.93 |
StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable | In Stock | £24.51 |
