StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC
Quicklinx: 9J41WS00 Mfr#: A50FBLCLC10
Length: 10m
Colour: Aqua
£33.25 ex VAT
£39.90 inc VAT
Deliver fast, reliable, data transfers, safely over high end networking equipment. The A50FBLCLC10 10m 850nm Laser-Optimized Multimode Fiber (LOMMF) Aqua Cord features 50/125 micron fiber for high-speed, high bandwidth data transmissions over 10 Gigabit Ethernet and Fiber Channel networks - the perfect solution for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM3) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
  • High compatibility
    Designed to seamlessly integrate with PC systems, this fiber optic cable ensures a reliable connection for all your networking needs.
  • Enhanced durability
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this cable is built for both safety and longevity, reducing the risk of smoke and toxic materials in case of fire.
  • High performance
    With a core and cladding diameter of 50 / 125 micron, this duplex cable supports 100G networks, ensuring high-speed data transmission for demanding applications.
  • Efficient connectivity
    Equipped with LC multi-mode connectors on both ends, this cable offers a secure and stable connection, minimizing insertion loss to less than 0.3dB for optimal signal integrity.
StarTech.com 10m (30ft) LC/UPC to LC/UPC OM3 Multimode Fiber Optic Cable, Full Duplex 50/125µm Zipcord Fiber Cable, 100G Networks, LOMMF/VCSEL, <0.3dB Low Insertion Loss - LSZH Fiber Patch Cord - patch cable - 10 m - aqua
Patch cable
Duplex fibre optic
Type of Fibre Optics
Multimode
Length
10 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
P/N: 455883B21ST, EXSFP10GESRS, J9150AST, J9152AST, MASFP10GBSR, SFP10GBLRMST, SFP10GBSRST, SFP10GLRMST, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST, SV565FXHD4KU
Network Cable Type
Patch cable
Duplex fibre optic
Multimode
Jacket Material
Fibre Qty
2
50 / 125 micron
Length
10 m
Aqua
Connector
RoHS
9J41 StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £18.69
9J41 StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £20.04
9J41 StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £33.25
9J41 StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £16.47
9J41 StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £24.53
9J41 StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable In Stock £25.13
Length: 10m
Colour: Aqua
