StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 8SFSWS00 Mfr#: HDMM10MA
Length: 10m
41 in stock
£49.91 ex VAT
£59.89 inc VAT
Create Ultra HD connections between your High Speed HDMI-equipped devices, up to 10m away with no signal loss. The HDMM10MA 33 ft Active High Speed HDMI Cable features a built-in active signal booster for a connection distance of up to 33 feet (10m) between your HDMI-enabled devices, with no signal loss.
This durable yet lightweight cable features thinner HDMI wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the HDMI connectors in order to ensure that the device and the HDMI source are connected properly.
StarTech.com 10m Active CL2 In-wall High Speed HDMI Cable Ultra HD 4k x 2k - HDMI cable HDMI to HDMI - 10 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable (signal regeneration)
Cable Type
HDMI cable
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
10 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
NEC-CL2, RoHS
Length: 10m
Price Range Ex VAT: 0 - 50
