Create Ultra HD connections between your High Speed HDMI-equipped devices, up to 10m away with no signal loss. The HDMM10MA 33 ft Active High Speed HDMI Cable features a built-in active signal booster for a connection distance of up to 33 feet (10m) between your HDMI-enabled devices, with no signal loss.
This durable yet lightweight cable features thinner HDMI wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the HDMI connectors in order to ensure that the device and the HDMI source are connected properly.
- StarTech.com 10m Active CL2 In-wall High Speed HDMI Cable Ultra HD 4k x 2k - HDMI cable - 10 m
- Cable
- HDMI cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 10 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Active cable (signal regeneration)
- 2-year warranty
- Cable Type
- HDMI cable
- Technology
- Double shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 10 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- NEC-CL2, RoHS
- Limited warranty - 2 years
StarTech.com 80 ft Active High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £97.02 |
StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable | In Stock | £68.48 |
StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable | In Stock | £49.91 |
