StarTech.com 10GbE to SFP+ Media Converter
Quicklinx: JG6LWS00 Mfr#: MCM10GSFP2
£203.51 ex VAT
£244.21 inc VAT
Connect a Gigabit copper network to a Gigabit fiber network using an SFP+ transceiver of your choice.
High-Speed Copper-to-Fiber Conversion
This compact 10G media converter enables seamless copper-to-fiber connectivity for high-speed network upgrades and extended reach. Featuring an open SFP+ slot, it converts 10GBASE-T (RJ-45) to 10G fiber and supports multi-mode or single-mode transceivers (e.g., 10GBASE-SR/LR) for flexible deployment across enterprise and telecom environments.
Versatile Mounting and Deployment
Ideal for structured wiring closets, server rooms, or remote network upgrades, the converter supports wall-mount, DIN rail, and chassis installations. It can operate as a standalone device or integrate into a media converter chassis system.
Optimized for 10Gbps Networks
Built for 10G speeds, the converter supports 16K Jumbo Frames, auto MDI/MDI-X, and full-duplex flow control. With plug-and-play setup and reliable diagnostics, it ensures consistent performance across 10G links.
Efficient, Compact Design
With low 5.3W (typical) power consumption via 5V DC input, this power-efficient converter operates in environments ranging from 0°C to 50°C. It avoids PoE-related conflicts and is ideal for compact, power-sensitive deployments.
Startech - fibre media converter - 10GbE - TAA Compliant
Fibre media converter - SFP+ / RJ-45
Wall / rack / DIN rail mountable
Cabling Type
10GBase-LR, 10GBase-SR, 10GBase-X, 10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Transmission Medium
Fibre optic
AC 100-240 V
9.35 cm x 7 cm x 2.6 cm
216 g
TAA Compliant
Wired
Cabling Type
10GbE
Data Transfer Rate
10 Gbps
Status Indicators
Power, link/activity
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, 16 KB Jumbo Frame, single-mode, LED status indicators, multimode, compact
IEEE 802.3
1 x Ethernet 10GBase-X - SFP+ female , 1 x Ethernet 10GBase-T - RJ-45 female
Power adapter
MTBF
50,000 hours
Plug and Play, FCC, RoHS, WEEE
TAA Compliant
External power adapter
AC 100-240 V
5.3 watt
9.35 cm
7 cm
2.6 cm
216 g
Shipping Width
9.5 cm
Shipping Depth
14.9 cm
Shipping Height
9.2 cm
Shipping Weight
398 g
50 °C
5 - 95% RH (non-condensing)
