StarTech.com 10G PCIe Network Adapter Card
Quicklinx: H1T8WS00 Mfr#: ST10GSPEXNDP2
Wired / Wireless: Wired
Protocol: Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, Fast Ethernet + 2 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
Hurry, only 1 left in stock!
£120.03 ex VAT
£144.03 inc VAT
Install this 2-port 10GbE PCI Express (PCIe) Network Interface Card (NIC) into a server or computer to enable fast network speeds and enhanced network functionality by providing failover and redundancy protection to mission-critical servers/applications. This Card supports six speeds: 10/5/2.5/1Gbps and 100/10Mbps with auto-negotiation for instant compatibility with new and legacy hardware. In addition, 10GBASE-T and NBASE-T (2.5GBASE-T/5GBASE-T) capabilities ensure compatibility with the latest network switches and access points manufactured by Cisco ; HPE ; and Aruba Networks .
  • 10GbE Network Speeds
    This PCIe Network Card enables access to two high-bandwidth ethernet connections. As a result, it reduces network degradation when running data-intensive applications/processes such as FTPs, online storage/backup, and streaming online content. The Ethernet Network Card supports 10GBASE-T using existing Cat6 (or better) cable infrastructure.
  • Enhance Existing Hardware
    NBASE-T technology maximizes the capability of Cat5e copper infrastructure over distances of up to 100 meters. The Network Interface Card connects to a PCIe x4 3.0/4.0 (or higher) slot and comes with a full-height bracket preinstalled, and a low-profile bracket is included. This Card is compatible with Windows, Windows Server, and Linux operating systems. Take advantage of advanced features such as load balancing in server or network equipment, bridging two different networks on one system, Audio Video Bridging (AVB), VLAN tagging (802.1Q), 16K-byte Jumbo Frames, full-duplex (FDX), UEFI Secure Boot (SB), and Preboot eXecution Environment (PXE). The PCIe 10GbE NIC is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 2-Port 10Gbps PCIe Network Adapter Card, Network Card for PCs/Servers, Full-Height/Low-Profile PCIe Ethernet Card w/Jumbo Frames, NIC/LAN Interface Card - Marvell AQC113CS Chipset, PXE Boot (ST10GSPEXNDP2) - network adapter - PCIe 3.0 x4 - 10 Gigabit Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
PCI Specification Revision
PCIe 3.0, PCIe 4.0
Ports
2 cm x 14.5 cm x 6.5 cm
116 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T, Ethernet 10GBase-T, NBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE, 5GbE, 10GbE
Data Transfer Rate
10 Gbps
Jumbo frame size: 16000
Network / Transport Protocol
TCP/IP, UDP/IP
1 x Marvell AQC113CS
IEEE 802.3, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz, IEEE 802.3u, IEEE P802.3az, IEEE 802.1Q
Windows 8 / 8.1 / 10 / 11, Linux 3.10.x or later LTS versions only, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019
Network adapter
PCI Express 3.0 x4
PCIe 3.0, PCIe 4.0
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet, 10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
Status Indicators
Link/activity
WOL, EEE, PTP, Auto MDIX, PXE support, full duplex capability, promiscuous mode, VLAN Tagging, PXE boot, secure boot, AVB
Processor / Memory
2 x 10M/100M/1G/2.5/5/10 Gigabit Ethernet - RJ-45
Low-profile bracket, full-height bracket
FCC, RCM
Software Included
Drivers & Utilities
2 cm
14.5 cm
6.5 cm
116 g
Shipping Width
14.5 cm
Shipping Depth
21.5 cm
Shipping Height
3.5 cm
Shipping Weight
208 g
Limited warranty - 2 years , Technical support - assistance - lifetime
5 °C
50 °C
20 - 80% RH
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: 10 Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: 2.5 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
