StarTech.com 10G PCIe Network Adapter Card
Quicklinx: H13FWS00 Mfr#: ST10GSPEXNB2
Wired / Wireless: Wired
Protocol: Fast Ethernet, 10 Gigabit Ethernet, Ethernet, Gigabit Ethernet + 2 more
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
£127.85 ex VAT
£153.42 inc VAT
Install this single-port 10GbE PCI Express (PCIe) Network Interface Card (NIC) into a server or computer to enable faster network speeds and enhanced network functionality. This card supports six speeds: 10/5/2.5/1Gbps and 100/10Mbps. The variable speeds permit access to legacy hardware. Alternatively, the 10GBASE-T and NBASE-T capabilities ensure compatibility with the latest network switches and network access points manufactured by Cisco ; HPE ; and Aruba .
  • Increased Network Speeds
    This PCIe network card provides access to increased bandwidth. It reduces network slowdown/degradation when running data-intensive applications/processes such as FTPs, online storage/backup, and when streaming online content. NBASE-T technology maximizes the capability of Cat5e copper cabling over at distances of up to 100 meters. The Ethernet network card supports a 10 Gbps connection over copper using existing Cat6 (or better) copper cabling.
  • Enhance Existing Hardware
    The Network Interface Card connects via an available PCI Express x2 3.0/4.0 (or higher) expansion slot. The card is shipped with a standard-profile bracket and includes a low-profile bracket for installation in various systems. This card is compatible with Windows, Windows Server, and Linux. Take advantage of advanced features such as Audio-Video Bridging (AVB), VLAN tagging, 16 K jumbo frame, full-duplex, secure boot, and PXE. The PCI Express 10G NIC is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 1-Port 10Gbps PCIe Network Adapter Card, Network Card for PC/Server, Low Profile PCIe Ethernet Card w/Jumbo Frame Support, NIC/LAN Interface Card - Marvell AQC113CS Chipset, PXE Boot (ST10GSPEXNB2) - network adapter - PCIe 3.0 x2 - 10 Gigabit Ethernet x 1
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 3.0 x2
PCI Specification Revision
PCIe 3.0, PCIe 4.0
Ports
1.5 cm x 10.6 cm x 5.6 cm
73 g
Cabling Type
NBase-T
10Mb LAN, 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
1 x Marvell AQC113CS
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz, IEEE P802.3az
Windows 8 / 10 / 11, Linux 3.10.x or later LTS versions only
Network adapter
Plug-in card
PCI Express 3.0 x2
PCIe 3.0, PCIe 4.0
Ports
Wired
Cabling Type
NBase-T
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
Status Indicators
Link/activity
Full duplex capability, secure boot, EEE, 16 KB Jumbo Frame, VLAN Tagging, AVB, Auto MDIX, PXE boot
Processor / Memory
1 x 100M/1G/2.5/5/10 Gigabit Ethernet - RJ-45
Low-profile bracket
RoHS, RCM
1.5 cm
10.6 cm
5.6 cm
73 g
Shipping Width
3.5 cm
Shipping Depth
21 cm
Shipping Height
14.5 cm
Shipping Weight
151 g
Limited warranty - 2 years , Technical support - assistance - lifetime
60 °C
H13F StarTech.com 10G PCIe Network Adapter Card In Stock £120.03
Protocol: 10 Gigabit Ethernet
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Protocol: 5 Gigabit Ethernet
