StarTech.com 10ft VESA Certified DP Cable
Quicklinx: J1K1WS00 Mfr#: DP12-CABLE-10FTW
20 In Stock
£13.14 ex VAT
£15.76 inc VAT
The StarTech.com 10ft White VESA Certified DisplayPort 1.2 Cable with Latches is designed to meet the needs of high-performance video and audio enthusiasts. This cable supports high-definition visuals with resolutions up to 4K at 60Hz, and also caters to professional and gaming setups with 1080p support up to 240Hz and 2K at 144Hz. It doesn't stop at visuals; the cable is engineered to deliver an enhanced audio experience, supporting up to 7.1 audio channels and 8 audio channels, ensuring that your auditory experience is as rich and immersive as your visual one.
Beyond its performance capabilities, this DisplayPort cable is built for reliability and durability. The latched connector design ensures a secure connection to prevent accidental disconnections, while the shielded, halogen-free construction protects against electromagnetic interference and minimizes exposure to harmful substances. Additionally, the cable's support for DisplayPort Multi-Stream Transport (MST) allows for the daisy-chaining of multiple monitors, making it an ideal solution for creating an efficient and productive workspace. With a durable thermoplastic elastomer (TPE) jacket and strain relief, this cable is designed to withstand the rigors of daily use, ensuring a long-lasting and reliable connection for all your display needs.
  • High-quality visuals
    Experience stunning high-definition visuals with 1080p support up to 240Hz, 2K at 144Hz, and 4K at 60Hz, ensuring a smooth and immersive viewing experience for gaming, streaming, and professional applications.
  • Enhanced audio experience
    With support for up to 7.1 audio channels and 8 audio channels, this cable delivers a rich audio experience, complementing the high-quality visuals for a fully immersive entertainment and work setup.
  • Reliable connectivity
    Featuring latched connectors and a shielded, halogen-free design, this DisplayPort 1.2 cable ensures a secure, stable connection while minimizing exposure to harmful substances and protecting against electromagnetic interference.
  • Versatile performance
    Support for DisplayPort Multi-Stream Transport (MST) allows for daisy-chaining multiple monitors, enhancing productivity and creating an efficient workspace with extended or mirrored displays.
  • Durable design
    Constructed with a thermoplastic elastomer (TPE) jacket and strain relief, this cable is designed for durability and longevity, resisting wear and tear from daily use.
StarTech.com 10ft White VESA Certified DisplayPort 1.2 Cable with Latches - DisplayPort cable - DisplayPort to DisplayPort - 3 m
DisplayPort cable
Shielded
Halogen-free, passive cable, 4K60Hz support, 1080p support 240Hz, 2K144Hz support, strain relief, EMI protection, HBR2 support, DisplayPort Multi-Stream Transport (MST), 7.1 audio channel support, ABS housing, 21.6 Gbps data rate, 19 conductors, 3D support, 8 audio channels, daisy-chaining
Length
3 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.2
White
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Outside Diameter
7.5 mm
White
192 g
Connector
DisplayPort 1.2, RoHS, WEEE, VW-1, HDCP 1.3
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
200 g
