This high quality 10ft USB extension cable provides one USB A male connector and one USB A female connector, providing a high quality USB extension. The USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
- StarTech.com USB 2.0 Extension Cable A to A - USB extension cable - USB (M) to USB (F) - 10 ft - molded - beige - USBEXTAA10 - USB extension cable - USB to USB - 3.1 m
- Molded
- Length
- 3.1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Beige
- Limited lifetime warranty
- Designed For
- P/N: RKCONS1901GB, UUSBOTG
- Molded
- Length
- 3.1 m
- Beige
- Connector
- Designed For
