Elevate your viewing experience with the StarTech.com 10ft (3m) USB-C to DisplayPort Adapter Cable, capable of delivering 8K 60Hz resolution for breathtaking clarity and detail. This adapter cable is designed to connect your USB-C enabled device to a DisplayPort monitor, projector, or display, supporting both extend and mirror modes for versatile viewing options. With features like HDR and HDR10 support, a 32.4 Gbps data rate, and Display Stream Compression (DSC), it ensures a seamless, high-quality audiovisual experience. The cable is built to last, with EMI protection, an aluminum connector housing, and a durable Thermoplastic elastomer (TPE) jacket. It's compliant with standards, including USB4, Thunderbolt 3, Thunderbolt 4, and DisplayPort 1.4, ensuring compatibility with a wide range of devices. Whether for professional use, content creation, or entertainment, this adapter cable is a perfect solution for anyone looking to maximize their display's potential.
High-resolution support
Experience high visual quality with support for resolutions up to 7680 x 4320. This adapter cable makes it easy to enjoy detailed and immersive viewing experiences available, whether extending or mirroring your display. -
Advanced connectivity
Equipped with standards in connectivity, including USB4, Thunderbolt 3, Thunderbolt 4, and DisplayPort 1.4, this cable ensures compatibility with a wide range of devices and future-proofs your setup. -
Enhanced audio and video features
With 2 audio channels, HDR and HDR10 support, and a 32.4 Gbps data rate, this cable delivers a rich, dynamic audiovisual experience. Display Stream Compression (DSC) allows for high-resolution displays without compromising on performance. -
Robust build quality
Featuring an aluminum connector housing and a durable Thermoplastic elastomer (TPE) jacket, this cable is designed for longevity and resilience against electromagnetic interference, ensuring a stable, high-quality connection. -
Seamless compatibility
This adapter cable supports HDCP 1.3 and 1.4, making it compatible with a wide range of digital content protection standards. Enjoy seamless access to high-definition content without compatibility issues.
- StarTech.com 10ft (3m) USB-C to DisplayPort Adapter Cable, 8K 60Hz - video adapter cable - 24 pin USB-C to DisplayPort - 3 m
- Video adapter cable
- 8K60Hz support, 4K144Hz support, EMI protection, DisplayPort Alternate Mode support, HBR3 support, aluminium connector housing, HDR support, HDR10 support, 32.4 Gbps data rate, Display Stream Compression (DSC), Chipset Via Labs VL103, 2 audio channels
- Length
- 3 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 20 pin DisplayPort - male - latched
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4
- Grey, black
- 3-year warranty
- Jacket Material
- Thermoplastic elastomer (TPE)
- Length
- 3 m
- Outside Diameter
- 4.3 mm
- Grey, black
- Connector
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4, RoHS, WEEE, HDCP 1.3, HDCP 1.4
- Shipping Width
- 15 cm
- Shipping Depth
- 10 cm
- Shipping Height
- 10 cm
- 3-year warranty
