StarTech.com 10ft USB-C to DP Adapter Cable
Quicklinx: HSV3WS00 Mfr#: 142-USBC-DP-8K-10F
Length: 3m
£19.12 ex VAT
£22.94 inc VAT
Elevate your viewing experience with the StarTech.com 10ft (3m) USB-C to DisplayPort Adapter Cable, capable of delivering 8K 60Hz resolution for breathtaking clarity and detail. This adapter cable is designed to connect your USB-C enabled device to a DisplayPort monitor, projector, or display, supporting both extend and mirror modes for versatile viewing options. With features like HDR and HDR10 support, a 32.4 Gbps data rate, and Display Stream Compression (DSC), it ensures a seamless, high-quality audiovisual experience. The cable is built to last, with EMI protection, an aluminum connector housing, and a durable Thermoplastic elastomer (TPE) jacket. It's compliant with standards, including USB4, Thunderbolt 3, Thunderbolt 4, and DisplayPort 1.4, ensuring compatibility with a wide range of devices. Whether for professional use, content creation, or entertainment, this adapter cable is a perfect solution for anyone looking to maximize their display's potential.
  • High-Resolution HDR Video
    This USB-C to DisplayPort Cable enables resolutions of up to 8K 60Hz and is DisplayPort 1.4 compliant. It supports HDR10, DSC, and 2 channel audio. *DSC support required to reach maximum resolution capabilities on Intel 11th Gen or later **Apple MacBook's with M1/M2/M3 Pro/Max silicon do not support 8K 60Hz over USB-C DP Alt Mode
  • Universal Compatibility
    The USB-C to DisplayPort Converter Cable is compatible with laptops and devices from various brands such as Dell, HP, Lenovo, Microsoft, and more. It works with all hardware platforms and any operating system. The USB Type-C to DisplayPort Cable requires no drivers or software and works with USB-C DP Alt Mode, USB4, Thunderbolt 3, and Thunderbolt 4 laptops and devices.
  • Thoughtfully Designed
    Combining a video adapter and cable minimizes potential points of failure and signal loss. A latching DisplayPort connector reduces the risk of accidental disconnections. The cable is equipped with aluminum connector shells, providing enhanced durability, and shielding from Electromagnetic Interference (EMI).
StarTech.com 10ft (3m) USB-C to DisplayPort Adapter Cable, 8K 60Hz - video adapter cable - 24 pin USB-C to DisplayPort - 3 m
Video adapter cable
8K60Hz support, 4K144Hz support, DisplayPort Alternate Mode support, HDR10 support, HDR support, Display Stream Compression (DSC), aluminium connector housing, EMI protection, HBR3 support, 32.4 Gbps data rate, 2 audio channels, Chipset Via Labs VL103
Length
3 m
Connector
24 pin USB-C - male
Connector (Second End)
20 pin DisplayPort - male - latched
USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4
Black, grey
3-year warranty
Video adapter cable
Jacket Material
Length
3 m
Outside Diameter
4.3 mm
Black, grey
Connector
24 pin USB-C - male
USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4, WEEE, RoHS, HDCP 1.3, HDCP 1.4
Shipping Width
15 cm
Shipping Depth
10 cm
Shipping Height
10 cm
3-year warranty
Length: 3m
