StarTech.com 10ft USB-C Charging Cable
Quicklinx: J4KMWS00 Mfr#: S2CEPR3M-USBSL-CABLE
Length: 3m
17 In Stock
£16.49 ex VAT
£19.78 inc VAT
Connect a charger or hub to a USB Power Delivery (PD) 3.1-enabled device, using this USB-C Charging Cable. The USB-C charger cord delivers up to 240W of Extended Power Range (EPR) Power Delivery and 5A output for fast charging. The connector markings enable quick visual identification, distinguishing it from other similar-looking or unmarked USB-C cables. Eliminate guesswork and always choose the right Type-C cable to support full 240W charging. This cable features dual locking screws that can securely connect to your USB-C peripherals and can prevent accidental disconnection from your devices. The knurled screws can be removed from the cable completely allowing it to be used as a standard USB-C cable if required. The USB-C EPR Charging Cable features a silicone inner jacket with a braided nylon exterior for optimal flexibility and wear protection. The durable nickel-plated connectors are designed for frequenty daily use, and are rated to operate beyond 20,000 insertion cycles. Charge a USB-C device with a USB-C wall charger, car charger, or power bank. The 3-meter (9.8-foot) USB Type-C cable is the ideal length for desk and mobile workstations where extra length is desired. With up to 5A of output, the USB-C Charger Cord supports up to 240W of Power Delivery to charge a USB-C laptop, or fast charge a tablet or smartphone. To use, connect the cable from a USB-C laptop to a USB-C wall charger.
  • Durable construction
    The cable is built with rugged materials that provide a wear-resistant surface, ensuring longevity and resistance to daily wear and tear.
  • Fast charging support
    It is equipped with USB Power Delivery support, enabling rapid charging for compatible devices.
  • High-speed data transfer
    The cable facilitates a data rate of 480 Mbps, allowing for quick syncing of files between devices.
  • Extensive bend lifespan
    Designed with over 20,000 bends in mind, this cable can withstand frequent use without compromising performance.
  • Effective EMI protection
    Featuring a shielded design, it protects against electromagnetic interference, ensuring stable connectivity during use.
StarTech.com 10ft (3m) USB-C Charging Cable, 240W, Silicone Jacket - USB-C cable - 24 pin USB-C to 24 pin USB-C - 3 m
USB-C cable
Shielded
USB Power Delivery (240W), Power Delivery 3.1 support, extended power range (EPR), sync and charge, rugged, fast charging support, wear-resistant, e-marker chip, EMI protection, 480 Mbps data rate, 20000+ bend lifespan, ABS connector housing, halogen free
Length
3 m
Connector
24 pin USB-C - male - straight/locking
Connector (Second End)
Rated Voltage
48 V
Rated Current
5 A
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Rated Voltage
48 V
Rated Current
5 A
Plated Connector
Nickel
Length
3 m
Outside Diameter
4.7 mm
154 g
Connector
USB / USB 2.0, USB-IF, RoHS, WEEE, FCC
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
2 cm
Shipping Weight
160 g
Length: 3m
