Product
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VCWS00 Mfr#: USBEXTAA10BK
Length: 3m
More than 50 in stock
£3.83 ex VAT
£4.59 inc VAT
Standard delivery Delivered within 3-5 working days
The USBEXTAA10BK 10-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 10 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
StarTech.com 10 ft Black USB 2.0 Extension Cable A to A - M/F - USB extension cable - 3 m
USB extension cable
Double shielded
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
3 m
Connector
USB / USB 2.0, RoHS
P/N: 35FCREADBK3
76VC StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.17
76VC StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
76VC StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
76VC StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.16
76VC StarTech.com 6 ft Transparent USB 2.0 Cable - A to B In Stock £3.66
76VC StarTech.com 3 ft A Right Angle to B Right Angle USB Cable - M/M In Stock £4.10
76VC StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £3.83
76VC StarTech.com 3m USB 2.0 A to B Cable - M/M In Stock £3.96
Length: 3m
Price Range Ex VAT: 0 - 50
