The USBEXTAA10BK 10-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 10 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
Enhanced durability
Featuring a double-shielded technology, this 10 ft Black USB 2.0 Extension Cable ensures a reliable connection with enhanced durability, making it perfect for prolonged use in any setting. -
Universal compatibility
Designed to connect with both Mac and PC platforms, this USB extension cable offers versatile connectivity options. Its universal compatibility ensures seamless integration with a wide range of devices. -
Extended reach
The 10 ft length of the USB 2.0 Extension Cable provides the extra reach needed to connect devices in hard-to-reach places, offering greater flexibility and convenience in device setup and use.
- StarTech.com 10 ft Black USB 2.0 Extension Cable A to A - 10ft USB 2.0 Extension Cable - 10ft USB male female Cable (USBEXTAA10BK) - USB extension cable - USB to USB - 3 m
- Technology
- Double shielded
- Length
- 3 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, UUSBOTG
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.94 |
StarTech.com Micro USB to Mini USB Adapter | In Stock | £4.79 |
StarTech.com Mini USB to Micro USB Adapter | In Stock | £4.82 |
StarTech.com 6in Mini USB 2.0 Cable - A to Mini B | In Stock | £4.03 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £4.97 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.17 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.28 |
StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £4.61 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.61 |
StarTech.com 3m USB 2.0 A to B Cable - M/M | In Stock | £4.61 |
StarTech.com 6in Micro USB to Mini USB Adapter Cable M/F | In Stock | £6.69 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.50 |
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.30 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.33 |
StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F | In Stock | £4.10 |
StarTech.com 3ft Right Angle Micro-USB Cable | In Stock | £5.15 |
StarTech.com 6ft Right Angle Micro-USB Cable | In Stock | £6.09 |
StarTech.com 3ft Micro-USB Charging Cable | In Stock | £5.00 |
StarTech.com 3 ft Micro-USB Charging Cable | In Stock | £5.00 |
StarTech.com 6 ft Micro-USB Charging Cable | In Stock | £8.29 |
StarTech.com 6 ft Micro-USB Charging Cable | In Stock | £8.27 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.69 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.74 |
