StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F
Quicklinx: 76VCWS00 Mfr#: USBEXTAA10BK
Length: 3m
41 In Stock
£5.00 ex VAT
£6.00 inc VAT
The USBEXTAA10BK 10-foot USB Extension Cable (A-A) features 1 USB A male connector and 1 USB A female connector, extending the connection between USB 2.0 devices by up to 10 feet - an ideal solution for better placement of peripheral devices, or adding flexibility to existing USB ports. This high quality USB extension cable is fully rated for use with USB 1.1 and USB 2.0 devices.
  • Enhanced durability
    Featuring a double-shielded technology, this 10 ft Black USB 2.0 Extension Cable ensures a reliable connection with enhanced durability, making it perfect for prolonged use in any setting.
  • Universal compatibility
    Designed to connect with both Mac and PC platforms, this USB extension cable offers versatile connectivity options. Its universal compatibility ensures seamless integration with a wide range of devices.
  • Extended reach
    The 10 ft length of the USB 2.0 Extension Cable provides the extra reach needed to connect devices in hard-to-reach places, offering greater flexibility and convenience in device setup and use.
StarTech.com 10 ft Black USB 2.0 Extension Cable A to A - 10ft USB 2.0 Extension Cable - 10ft USB male female Cable (USBEXTAA10BK) - USB extension cable - USB to USB - 3 m
USB extension cable
Double shielded
Length
3 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: 35FCREADBK3, ICUSB2321F, ICUSB232PRO, ICUSB232V2, LTUB1MBK, MSDREADU2OTG, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
3 m
Connector
USB / USB 2.0, RoHS
76VC StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £5.29
76VC StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
76VC StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
76VC StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
76VC StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
76VC StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £4.92
76VC StarTech.com 3m USB 2.0 A to B Cable - M/M In Stock £4.51
76VC StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £16.70
76VC StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £6.37
76VC StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
76VC StarTech.com 3ft Right Angle Micro-USB Cable In Stock £5.22
76VC StarTech.com 6ft Right Angle Micro-USB Cable In Stock £6.70
76VC StarTech.com 3ft Micro-USB Charging Cable In Stock £4.95
76VC StarTech.com 6 ft Micro-USB Charging Cable In Stock £7.99
76VC StarTech.com 0.5m Angled Micro USB Cable In Stock £4.71
Length: 3m
