StarTech.com 10ft Ultra High Speed HDMI 2.1
Quicklinx: GJK3WS00 Mfr#: HDMM21V3M
Length: 3m
More than 50 In Stock
£23.74 ex VAT
£28.48 inc VAT
Certified Ultra High Speed HDMI 2.1 - 8K 60Hz - 9.8 ft. (3 m)
This 9.8 ft. (3 m) Ultra High Speed HDMI 2.1 Certified Cable withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, this durable cable is a must-have for both business and consumer applications.
Experience the latest that HDMI 2.1 has to offer
This high performance 8K cable supports resolutions of up to 8K at 60Hz (7680x4620p), 5K at 60Hz, 4K at 120Hz and bandwidths of up to 48Gbps. It also supports HDR10+ (High Dynamic Range) and Dolby Vision for higher contrast ratio and vivid colors.
Plus, eARC (Enhanced Audio Return Channel) has up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio , DTS:X , Dolby TrueHD, Dolby Atmos for high quality sound. Latest HDCP 2.3 encrypts and secures your video and audio content.
With higher resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect an enhanced video experience. The cable is guaranteed to provide the very best HDMI 8K performance available today. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage.
This cable works with all 8K ready devices and is also backward compatible with previous HDMI specifications.
Provide superior connections with Ultra High Speed certification
The cable has undergone rigorous compliance testing and is certified by an HDMI Authorized Test Center to ensure it supports the high bandwidth enabled features it promises. An EMI test is also performed to ensure the cable minimizes interference with wireless signals.
Cable Key Features
Aluminum-mylar foil with braided shielding improve EMI protection
Long lasting flexible TPE jacket & strain relief (TPE is non-toxic & halogen free for environmental sustainability)
Insulated conductors reduce friction, provide more flexibility
Connector Key Features
Die-cast aluminium sub-structure shielding improves signal integrity & prevents signal degradation
Corrosion-free gold-plated connectors ensure premium video quality & enhanced reliability
Tested to withstand 10,000+ insertions
The HDMM21V3M is backed by StarTech.com's Lifetime Warranty.
  • Experience exceptional HDMI 2.1
    This high-performance 8K cable supports resolutions of up to 8K at 60Hz (7680x4620p), 5K at 60Hz, 4K at 120Hz and bandwidths of up to 48Gbps. It also supports HDR10+ (High Dynamic Range) and Dolby Vision for higher contrast ratio and vivid colors. Plus, eARC (Enhanced Audio Return Channel) has up to 32 uncompressed 5.1 and 7.1 digital audio channels to support DTS-HD Master Audio, DTS:X, Dolby TrueHD, Dolby Atmos for high quality sound. HDCP 2.3 encrypts and secures your video and audio content. With higher resolutions, increased speeds, sharper images, and crystal-clear audio, you can expect an enhanced video experience. The cable is guaranteed to provide incredible HDMI 8K performance. It's the perfect cable for creating the ultimate home theater or for providing lifelike digital signage. This cable works with all 8K ready devices and is also backward compatible with previous HDMI specifications.
  • Provide excellent connections with Ultra High Speed certification
    The cable supports the high bandwidth enabled features. The cable also minimizes interference with wireless signals.
StarTech.com 10ft (3m) HDMI 2.1 Cable, Certified Ultra High Speed HDMI Cable 48Gbps, 8K 60Hz/4K 120Hz HDR10+ eARC, Ultra HD 8K HDMI Cable/Cord w/TPE Jacket, For UHD Monitor/TV/Display - Dolby Vision/Atmos, DTS-HD (HDMM21V3M) - HDMI cable with Ethernet - 3 m
Cable
Ultra High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
30/32
Length
3 m
Grey, black
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K120Hz support, 8K60Hz (7680 x 4320) support
P/N: 4PORT-8K-HDMI-SWITCH
Cable Type
Ultra High Speed - HDMI cable with Ethernet passive, 4K120Hz support, 8K60Hz (7680 x 4320) support
Shielded
30/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
3 m
Plated Connector
Gold
Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, Enhanced Audio Return Channel (eARC), Dolby DTS:X support, Dolby Vision, 48Gbps support, support HDR10+, strain relief, outer diameter 6mm
Grey, black
Connector
19 pin HDMI Type A - male
RoHS, HDCP 2.3
Shipping Width
39.5 cm
Shipping Depth
13.8 cm
Shipping Height
5 cm
Shipping Weight
120 g
Limited warranty - lifetime
GJK3 StarTech.com 12ft Ultra High Speed HDMI 2.1 In Stock £33.33
GJK3 StarTech.com 20in Ultra High Speed HDMI 2.1 In Stock £14.15
Length: 3m
