StarTech.com 10ft Slim Micro USB 3.0 Cable
Quicklinx: B27KWS00 Mfr#: USB3AUB3MS
Hurry, only 1 left in stock!
£12.79 ex VAT
£15.34 inc VAT
Position your USB 3.0 Micro devices near your desktop or laptop easily, with a thin, more flexible cable. Does your regular USB 3.0 cable lift or push against your external hard drive causing it to move around on your desk? Are you forced to arrange your desk according to how your cable decides to bend and rest?
The USB3AUB3MS features a slim USB wire construction that makes it easier to install your USB 3.0 devices and enables you to place them as needed throughout your workspace. Plus, the thin Micro USB connector molding makes this a great cable for mobile USB 3.0 devices too - it lets you plug into your device without having to take it out of its case for every charge and sync.
Organize your desk and your office to match your needs. This durable, lightweight cable is approximately half the thickness of a regular USB 3.0 cable giving you the freedom to place your devices as needed and with minimal clutter. The flexible, thin cable also reduces strain on the connection and prevents damage to the USB 3.0 port on your device.
Provide full charging power, with no loss of charge time, even at distances of up to 10 feet (3 meters) away from your charger.
As well as being ideal for connecting to your desktop devices, this cable provides the perfect solution for charging and syncing your USB 3.0 Micro B-equipped phones and tablets.
The long charge cable overcomes distance restrictions and lets you stay connected even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a thin Micro USB connector molding that plugs into your device even while it's inside a protective case.
StarTech.com 3m 10ft Slim USB 3.0 A to Micro B Cable M/M - Mobile Charge Sync USB 3.0 Micro B Cable for Smartphones and Tablets (USB3AUB3MS) - USB cable - Micro-USB Type B to USB Type A - 3 m
USB cable
Double shielded
Molded, 5 Gbps data rate
Length
3 m
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: S2510BU33PW, S251BMU3FP, S251BRU33, SLSODDU33B, SM2NGFFMBU33
USB cable
Double shielded
American Wire Gauge (AWG)
24/30/32
Plated Connector
Nickel
Length
3 m
Connector
USB 3.0, RoHS
