StarTech.com 10ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJVWS00 Mfr#: DP14VMM3M
Length: 3m
£30.05 ex VAT
£36.06 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 9.8 ft. (3 m).
StarTech.com 10ft (3m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM3M) - DisplayPort cable - DisplayPort to DisplayPort - 3 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Length
3 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
3 m
Outside Diameter
7.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
33 cm
Shipping Depth
25.5 cm
Shipping Height
2 cm
Shipping Weight
253 g
Length: 3m
