StarTech.com 10ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJVWS00 Mfr#: DP14VMM3M
Length: 3m
More than 50 In Stock
£20.57 ex VAT
£24.68 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 9.8 ft. (3 m).
  • High-resolution support
    This cable supports resolutions up to 8K at 60 Hz and 4K at 120 Hz, making it suitable for high-end displays and gaming applications.
  • Efficient data transmission
    Featuring a data rate of 32.4 Gbps, this cable allows for fast and reliable transmission of video and audio signals with minimal quality loss.
  • Durable shielding
    The aluminum mylar foil and braid shielding effectively reduce interference, ensuring a stable connection for your devices.
  • Flexible compatibility
    Compliant with standards such as HDCP 2.2 and RoHS, this cable can be used with a variety of setups without compromising performance.
  • Enhanced audio experience
    Support for up to 32 audio channels, along with HDR10, delivers an immersive audio experience alongside stunning visuals.
StarTech.com 10ft (3m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM3M) - DisplayPort cable - DisplayPort to DisplayPort - 3 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Length
3 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
3 m
Outside Diameter
7.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
33 cm
Shipping Depth
25.5 cm
Shipping Height
2 cm
Shipping Weight
253 g
Length: 3m
