Connect an 8K 60Hz or a 4K 144Hz HDMI display to a DP Alt Mode-enabled USB Type-C source, at a distance of up to 9.8ft (3m), using this USB-C to HDMI Adapter Cable.
High-Resolution HDR Video
This USB-C to HDMI Cable enables resolutions of up to 8K 60Hz and is HDMI 2.1 FRL complaint. It supports HDR10, HDCP 1.x/2.2/2.3, and DSC 1.1/1.2a. The adapter cable supports 7.1 channel audio with Dolby Atmos and DTS:X. *DSC support required to reach maximum resolution capabilities on Intel 11th Gen or later **Apple MacBook's with M1/M2 silicon can only support up to 4K 60Hz through HDMI -
Universal Compatibility
The USB-C to HDMI Converter Cable is compatible with laptops and devices from various brands such as Dell, HP, Lenovo, Microsoft, and more. It works with all hardware platforms and any operating system. The USB Type-C to HDMI Cable requires no drivers or software and works with USB-C DP Alt Mode, USB4, Thunderbolt 3, and Thunderbolt 4 laptops and devices. Note: Apple M1/M2 devices, including MacBook Pro, can only support up to 4K 60Hz over USB-C DP Alt Mode and cannot achieve 8K 60Hz. -
Thoughtfully Designed
Combining a video adapter and cable minimizes potential points of failure and signal loss. Adaptive receiver equalization optimizes the input signal and amplifies the output signal to ensure compatibility with high-resolution monitors. The cable is equipped with cage shielding to prevent Electromagnetic Interference (EMI).
- StarTech.com 10ft (3m) USB-C to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, USB Type-C to HDMI 2.1 Video Converter Cable, USB-C DP Alt Mode/USB4/Thunderbolt 3/4 Compatible - USB-C Laptop to HDMI Monitor (136B-USBC-HDMI213M) - adapter cable - 3 m
- Cable
- Adapter cable
- Max Output Resolution
- 7680 x 4320 - 60 Hz
- Length
- 3 m
- Space grey
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- HDMI - male
- USB4 / Thunderbolt 3 / Thunderbolt 4
- 8K60Hz support, 4K144Hz support, active adapter
- 3-year warranty
- Cable Type
- Adapter cable 8K60Hz support, 4K144Hz support, active
- Jacket Material
- PVC
- Length
- 3 m
- Support HDR10, Dolby Atmos support, DTS:X support, DisplayPort Alternate Mode support, VMM7100 chipset, wide screen support, 7.1 audio channel support (HDMI), outer diameter 4.8mm
- Space grey
Adapters & Converters
- 7680 x 4320
- Refresh Rate
- 60 Hz
- Connector
- 19 pin HDMI Type A - male
- RoHS, WEEE, EMI, HDCP 2.2, HDCP 2.3, DSC 1.1, DSC 1.2a, HDCP
- 121 g
- Shipping Width
- 14.9 cm
- Shipping Depth
- 21.3 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 207.8 g
- Limited warranty - 3 years
