StarTech.com 10ft/3m USB-C to HDMI Adapter Cable
Quicklinx: HM9HWS00 Mfr#: 136B-USBC-HDMI213M
Length: 3m
10 In Stock
£40.86 ex VAT
£49.03 inc VAT
Connect an 8K 60Hz or a 4K 144Hz HDMI display to a DP Alt Mode-enabled USB Type-C source, at a distance of up to 9.8ft (3m), using this USB-C to HDMI Adapter Cable.
  • High-Resolution HDR Video
    This USB-C to HDMI Cable enables resolutions of up to 8K 60Hz and is HDMI 2.1 FRL complaint. It supports HDR10, HDCP 1.x/2.2/2.3, and DSC 1.1/1.2a. The adapter cable supports 7.1 channel audio with Dolby Atmos and DTS:X. *DSC support required to reach maximum resolution capabilities on Intel 11th Gen or later **Apple MacBook's with M1/M2 silicon can only support up to 4K 60Hz through HDMI
  • Universal Compatibility
    The USB-C to HDMI Converter Cable is compatible with laptops and devices from various brands such as Dell, HP, Lenovo, Microsoft, and more. It works with all hardware platforms and any operating system. The USB Type-C to HDMI Cable requires no drivers or software and works with USB-C DP Alt Mode, USB4, Thunderbolt 3, and Thunderbolt 4 laptops and devices. Note: Apple M1/M2 devices, including MacBook Pro, can only support up to 4K 60Hz over USB-C DP Alt Mode and cannot achieve 8K 60Hz.
  • Thoughtfully Designed
    Combining a video adapter and cable minimizes potential points of failure and signal loss. Adaptive receiver equalization optimizes the input signal and amplifies the output signal to ensure compatibility with high-resolution monitors. The cable is equipped with cage shielding to prevent Electromagnetic Interference (EMI).
StarTech.com 10ft (3m) USB-C to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, USB Type-C to HDMI 2.1 Video Converter Cable, USB-C DP Alt Mode/USB4/Thunderbolt 3/4 Compatible - USB-C Laptop to HDMI Monitor (136B-USBC-HDMI213M) - adapter cable - 3 m
Cable
Adapter cable
Max Output Resolution
7680 x 4320 - 60 Hz
Length
3 m
Space grey
Connector
24 pin USB-C - male
Connector (Second End)
HDMI - male
USB4 / Thunderbolt 3 / Thunderbolt 4
8K60Hz support, 4K144Hz support, active adapter
3-year warranty
Cable Type
Adapter cable 8K60Hz support, 4K144Hz support, active
Jacket Material
PVC
Length
3 m
Support HDR10, Dolby Atmos support, DTS:X support, DisplayPort Alternate Mode support, VMM7100 chipset, wide screen support, 7.1 audio channel support (HDMI), outer diameter 4.8mm
Space grey
Adapters & Converters
7680 x 4320
Refresh Rate
60 Hz
Connector
24 pin USB-C - male
19 pin HDMI Type A - male
RoHS, WEEE, EMI, HDCP 2.2, HDCP 2.3, DSC 1.1, DSC 1.2a, HDCP
121 g
Shipping Width
14.9 cm
Shipping Depth
21.3 cm
Shipping Height
5.1 cm
Shipping Weight
207.8 g
Limited warranty - 3 years
Length: 3m
