StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered
Quicklinx: FLWDWS00 Mfr#: VGA2VID2
£44.05 ex VAT
£52.86 inc VAT
Computer to TV Converter 1080p to 480i Scaler , Composite & S-Video 2-Year Warranty. This VGA to RCA/S-Video converter box provides a simple way to convert and scale a 1080p VGA video input signal to a 480i composite (CVBS) or S-Video output signal. Perfect for use with legacy projectors or TV sets.
Hassle-Free Setup and Easy to Use
Equipped with a NTSC/PAL toggle switch and a scan button for simple configuration and selection of your video output settings, this compact VGA to Composite and S-Video adapter installs quickly and easily, for a true plug-and-play experience.
Save on Upgrade Costs
By using this VGA to AV adapter you can connect a PCs VGA connector to legacy TVs and projectors, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching videos on your S-Video or Composite display.
Crystal-Clear Picture Quality
The PC to television converter features an integrated video scaler circuit that dynamically converts VGA video input signals with resolutions up to 1920x1200 @ 60Hz. To ensure compatibility with your display or projector the computer to TV converter outputs high quality 720 x 480 video, the highest supported by S-Video or Composite.
VGA2VID2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Hassle-Free Setup and Easy to Use
  • Save on Upgrade Costs
  • Crystal-Clear Picture Quality
    The PC to television converter features an integrated video scaler circuit that dynamically converts VGA video input signals with resolutions up to 1920x1200 @ 60Hz. To ensure compatibility with your display or projector the computer to TV converter outputs high quality 640 x 480 video, the highest supported by S-Video or Composite. VGA2VID2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered - adapter - VGA / S-Video / composite video
Cable
Adapter - VGA / S-Video / composite video
Max Output Resolution
640 x 480 - 60 Hz
Connectors
HD-15 (VGA) - female
Connectors (Second End)
4 pin mini-DIN - female , RCA - female
Active cable
Cable Type
Adapter active
Interface Supported
Recommended Use
TV
USB powered
Adapters & Converters
640 x 480
Refresh Rate
60 Hz
Connectors
15 pin HD D-Sub (HD-15) - female
FCC, RoHS, WEEE, REACH
5.4 cm
6 cm
2 cm
46 g
Shipping Width
13.3 cm
Shipping Depth
10.5 cm
Shipping Height
2.4 cm
Shipping Weight
162 g
FLWD StarTech.com 2m USB-C to VGA Cable In Stock £21.49
