Computer to TV Converter 1080p to 480i Scaler , Composite & S-Video 2-Year Warranty. This VGA to RCA/S-Video converter box provides a simple way to convert and scale a 1080p VGA video input signal to a 480i composite (CVBS) or S-Video output signal. Perfect for use with legacy projectors or TV sets.
Hassle-Free Setup and Easy to Use
Equipped with a NTSC/PAL toggle switch and a scan button for simple configuration and selection of your video output settings, this compact VGA to Composite and S-Video adapter installs quickly and easily, for a true plug-and-play experience.
Save on Upgrade Costs
By using this VGA to AV adapter you can connect a PCs VGA connector to legacy TVs and projectors, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching videos on your S-Video or Composite display.
Crystal-Clear Picture Quality
The PC to television converter features an integrated video scaler circuit that dynamically converts VGA video input signals with resolutions up to 1920x1200 @ 60Hz. To ensure compatibility with your display or projector the computer to TV converter outputs high quality 720 x 480 video, the highest supported by S-Video or Composite.
VGA2VID2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
Equipped with a NTSC/PAL toggle switch and a scan button for simple configuration and selection of your video output settings, this compact VGA to Composite and S-Video adapter installs quickly and easily, for a true plug-and-play experience. -
By using this VGA to AV adapter you can connect a PCs VGA connector to legacy TVs and projectors, ultimately saving the costs of upgrading your equipment. It's ideal for boardroom settings, medical imaging and watching videos on your S-Video or Composite display. -
The PC to television converter features an integrated video scaler circuit that dynamically converts VGA video input signals with resolutions up to 1920x1200 @ 60Hz. To ensure compatibility with your display or projector the computer to TV converter outputs high quality 640 x 480 video, the highest supported by S-Video or Composite. VGA2VID2 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered - adapter - VGA / S-Video / composite video
- Cable
- Adapter - VGA / S-Video / composite video
- Max Output Resolution
- 640 x 480 - 60 Hz
- Black
- Connectors
- HD-15 (VGA) - female
- Connectors (Second End)
- 4 pin mini-DIN - female , RCA - female
- Active cable
- 2-year warranty
- Cable Type
- Adapter active
- Interface Supported
- Recommended Use
- TV
- USB powered
- Black
Adapters & Converters
- 640 x 480
- Refresh Rate
- 60 Hz
- Connectors
- 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS, WEEE, REACH
- 5.4 cm
- 6 cm
- 2 cm
- 46 g
- Shipping Width
- 13.3 cm
- Shipping Depth
- 10.5 cm
- Shipping Height
- 2.4 cm
- Shipping Weight
- 162 g
- Limited warranty - 2 years
