StarTech.com 1080p HDMI over IP Extender - Up to 492 ft. (150 m)
Quicklinx: FY2HWS00 Mfr#: ST12MHDLNV
HDMI Balun IR Extension IP or Direct Connection 2-Year Warranty. The HDMI Over IP Extender kit lets you extend an HDMI signal over your network or network cabling. You can use additional receivers (sold separately) to distribute the HDMI signal to multiple locations.
Point-to-Point Configuration
For smaller-scale applications, the HDMI video extender over Cat6 kit can be used as a point-to-point video extender up to 492 feet (150 meters). The 1080p HDMI extender units can even cascade the same signal to multiple receivers.
Flexible Installation
The HDMI Balun kit includes optional mounting hardware for a tidy installation. Ideal for corporate applications, the extender supports 1080p video resolutions and stereo audio. The HDMI extender over LAN uses standard Cat5e or Cat6 Ethernet cables with RJ45 connectors, it eliminates both the expense and hassle of running specialized cables. The local unit also features an HDMI output to avoid the need for an additional HDMI splitter.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales
The ST12MHDLNV is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • HDMI over IP extender
    Extend 1080p 60Hz HDMI video and 2ch stereo audio up to 492 ft. (150m) over Ethernet; YUV advanced video coding (supports 4:4:4 sampling & HDCP 1.4) to minimize network bandwidth.
  • Easy to install
    Simply connect through a 100Mbps or Gigabit Ethernet switch (managed/unmanaged) using network cable (RJ45 connectors); no IP configuration needed.
  • Direct connection
    Directly connect the transmitter to the receiver (without an Ethernet switch) up to 150m over CAT5e/CAT6 cable.
StarTech.com HDMI over IP Extender - 1080p HDMI Video over Ethernet/LAN Cat5e/Cat6 Network Cable - Transmitter/Receiver Kit - 490ft (150m) - video/audio/infrared extender - HDMI
Video/audio/infrared extender
External
Australia, North America, United Kingdom, Europe
HDMI
Max Transfer Distance
150 m
AC 120/230 V
7 cm x 12.5 cm x 2.6 cm
474 g
External
Wired
HDMI
Max Resolution
1920 x 1080 / 1080p @ 60 Hz
150 m
Status Indicators
Daisy-chaining support
1 x HDMI (input) - 19 pin HDMI Type A female , 2 x HDMI (output) - 19 pin HDMI Type A female , 1 x IR (input) - mini jack female , 1 x IR (output) - mini jack female
IR receiver, IR transmitter, 8 rubber feet, mounting screws
Mounting Kit
Included
FCC, RoHS, REACH, HDCP 1.4
External power adapter
AC 120/230 V
7 cm
12.5 cm
2.6 cm
474 g
Shipping Width
25.5 cm
Shipping Depth
30.6 cm
Shipping Height
6.7 cm
Shipping Weight
1.264 kg
70 °C
0 - 95%
FY2H StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
FY2H StarTech.com ST12MHDLAN4K Receiver In Stock £259.38
