StarTech.com 100Base-LH SFP - SM LC- 80 km
Quicklinx: D1VJWS00 Mfr#: SFP100BLHST
Add reliable and cost-effective 100-Mbps Ethernet connections over single-mode fiber, with this SFP module. This 100Base-LH SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 100Mbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable Fast Ethernet connectivity over single-mode fiber for 100Base-LH compliant networks, with a maximum distance of up to 80 km (49.7 mi.) and 1550 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com MSA Uncoded Compatible SFP Module, 100BASE-LH, 100MbE Single Mode (SMF) Fiber Optic Transceiver, 100Mb Ethernet SFP, LC Connector, 80km, 1550nm, DDM, Mini GBIC Module, 100Mbps - Lifetime Warranty (SFP100BLHST) - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
100Base-LH
Data Transfer Rate
155 Mbps
Optical Wave Length
1550 nm
100Mb LAN
Max Transfer Distance
80 km
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
100Base-LH
100Mb LAN
Data Transfer Rate
155 Mbps
Optical Wave Length
1550 nm
80 km
Half duplex mode, full duplex mode, Digital Diagnostics Monitoring Interface (DDMI), Digital Optical Monitoring (DOM) support
IEEE 802.3u
1 x Ethernet 100Base-LH - LC single-mode x 2
FCC, RoHS, WEEE, MSA, RCM
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
D1VJ StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £21.31
D1VJ StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.13
D1VJ StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.13
D1VJ StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.44
