StarTech.com's Category 6 cable is the perfect way to connect your emerging gigabit network. Category 6 cable improves upon the Category 5e specification by providing twice the available bandwidth (up to 500Mhz), and a signal-to-noise margin improvement that is sixteen times (12dB) better than that provided by Cat 5e.
StarTech.com's Cat 6 cable is constructed by highly trained staff using top quality components that ensure the final product meets StarTech.com's strict standards for reliability. These cables help StarTech.com maintain its tradition of offering top-notch parts and products for the best price possible.
High-frequency performance
Designed to support data transmission speeds for demanding computing environments, this Cat 6 Ethernet cable is tested for frequencies up to 500 MHz, ensuring optimal performance for your network applications. -
In-wall safety
The CM-rated design makes this 1000 ft bulk cable suitable for in-wall use, providing a secure and reliable solution for your networking infrastructure within building constructions. -
Flexible installation
Featuring a stranded design, this Ethernet cable offers enhanced flexibility, making it easier to install around corners and through tight spaces without compromising the integrity of the cable.
- StarTech.com 1000 ft Bulk Cat6 Ethernet Cable - Stranded - CM-Rated for In-Wall Use - Cat 6 UTP Patch Cable - Blue (WIRC6PATBLRL) - bulk cable - 305 m - blue
- Bulk cable - CAT 6
- Technology
- Stranded
- Length
- 305 m
- Blue
- Limited lifetime warranty
- Designed For
- P/N: IES61002POE, POEINJ1G, POEINJ1GW, POEINJ4G, ST1000SMPEX, ST2000PEXPSE, ST4000PEXPSE, UPOESPLT1G, USB110EXT2
- Network Cable Type
- Technology
- Stranded
- Length
- 305 m
- Blue
- Up to 500 MHz
- Designed For
