StarTech.com 1000Base-TX SFP - RJ45 Copper
Quicklinx: D1VCWS00 Mfr#: SFP1000TXST
Type: Modules
12 In Stock
£37.06 ex VAT
£44.47 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over copper, with this SFP module. This 1000Base-TX SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The RJ45 copper SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 1Gbps, this SFP module can be installed into networking equipment with an MSA compliant port and RJ45 copper interface. It delivers dependable Gigabit connectivity over copper cable for 1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft.).
This SFP transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this transceiver module is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com MSA Uncoded Compatible SFP Module, 1000BASE-TX, SFP to RJ45 (Copper) Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1Gbps/1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (SFP1000TXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1 Gbps
1GbE
Max Transfer Distance
100 m
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-TX
1GbE
Data Transfer Rate
1 Gbps
100 m
Full duplex mode
IEEE 802.3z
1 x Ethernet 1000Base-TX - RJ-45
FCC, RoHS, WEEE, MSA, RCM
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
Type: Modules
