StarTech.com 1000Base-SX SFP - MM LC- 550 m
Quicklinx: D1VBWS00 Mfr#: SFP1000SXST
Type: Modules
26 In Stock
£24.01 ex VAT
£28.81 inc VAT
Add reliable and cost-effective Gigabit Ethernet connections over multimode fiber, with this SFP module. This 1000Base-SX SFP module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The multimode SFP transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 1Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable Gigabit connectivity over multimode fiber for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft.) and 850 nm optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
  • Reliable connectivity
    The Ethernet 1000Base-SX type provides robust wired connectivity, ensuring dependable connections for networking needs.
  • Effective temperature range
    With a maximum operating temperature of 70°C, this module performs well under various environmental conditions, making it suitable for diverse applications.
  • Extended transfer distance
    Achieving effective transmission over distances up to 550 meters allows for versatile deployment in larger networking setups.
  • Compliance with standards
    Meets several industry standards, including FCC and IEEE 802.3z, validating its reliability and safety for various networking configurations.
  • Monitoring features
    Supports Digital Optical Monitoring (DOM) and Digital Diagnostics Monitoring (DDM), providing real-time status and ensuring network integrity.
StarTech.com MSA Uncoded Compatible SFP Module, 1000BASE-SX, 1GbE Multi Mode (MMF) Fiber Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, 1Gbps Mini GBIC Module - Lifetime Warranty (SFP1000SXST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.39 cm x 5.84 cm x 1.26 cm
30 g
P/N: US1GA30SFP, US1GC30SFP
Plug-in module
Silver
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
850 nm
550 m
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
FCC, RoHS, WEEE, MSA, RCM
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
Type: Modules
