The MASFP1GBLX10 is a Cisco Meraki MA-SFP-1GB-LX10 compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco Meraki brand switches and routers. It delivers dependable 1GbE (100Mbps) connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Reliable connectivity
This SFP module provides stable wired connections, suitable for Gigabit Ethernet applications ensuring consistent network performance. -
Digital monitoring capabilities
Features such as Digital Optical Monitoring and Digital Diagnostics Monitoring allow users to keep track of the module's status and optimize performance. -
Wide operating temperature range
Designed to function in environments varying from 0°C to 70°C, this module is versatile and adaptable to multiple operational conditions. -
Long-distance data transmission
With a maximum transfer distance of 10 km, this module enables effective communication across greater distances within a network. -
Compliant with key standards
Meets various regulatory standards, ensuring safety, compatibility, and reliability in networking solutions.
- Startech Cisco Meraki MA-SFP-1GB-LX10 Compatible SFP Module, 1000BASE-LX, 1GbE SMF Optic Transceiver, 1GE Gigabit Ethernet LC Connector, 10km, 1310nm Cisco Meraki MS225, MX400, MS250 - Lifetime Warranty (MASFP1GBLX10) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-LX
- Data Transfer Rate
- 1.25 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-1GE-LX
- 1.37 cm x 5.66 cm x 1.25 cm
- 28 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-LX
- 1GbE
- 1.25 Gbps
- 1310 nm
- 10 km
- Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
- IEEE 802.3z
- 1 x Ethernet 1000Base-LX - LC single-mode female
- UL, FCC, RoHS, MSA
- 1.37 cm
- 5.66 cm
- 1.25 cm
- 28 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 95%
StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £21.31 |
StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £24.13 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £20.35 |
StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC | In Stock | £19.44 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com Fiber Media Converter - Open | In Stock | £43.33 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £328.89 |
