StarTech.com 1000Base LX10 Single-Mode
Quicklinx: B3GZWS00 Mfr#: MA-SFP-1GB-LX10
Type: Modules
16 In Stock
£36.73 ex VAT
£44.07 inc VAT
The MASFP1GBLX10 is a Cisco Meraki MA-SFP-1GB-LX10 compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco Meraki brand switches and routers. It delivers dependable 1GbE (100Mbps) connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable connectivity
    This SFP module provides stable wired connections, suitable for Gigabit Ethernet applications ensuring consistent network performance.
  • Digital monitoring capabilities
    Features such as Digital Optical Monitoring and Digital Diagnostics Monitoring allow users to keep track of the module's status and optimize performance.
  • Wide operating temperature range
    Designed to function in environments varying from 0°C to 70°C, this module is versatile and adaptable to multiple operational conditions.
  • Long-distance data transmission
    With a maximum transfer distance of 10 km, this module enables effective communication across greater distances within a network.
  • Compliant with key standards
    Meets various regulatory standards, ensuring safety, compatibility, and reliability in networking solutions.
StarTech.com Cisco Meraki MA-SFP-1GB-LX10 Compatible SFP Module, 1000BASE-LX, 1GbE SMF Optic Transceiver, 1GE Gigabit Ethernet LC Connector, 10km, 1310nm Cisco Meraki MS225, MX400, MS250 - Lifetime Warranty (MASFP1GBLX10) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
Juniper SFP-1GE-LX
1.37 cm x 5.66 cm x 1.25 cm
28 g
Plug-in module
Silver
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3z
1 x Ethernet 1000Base-LX - LC single-mode female
UL, FCC, RoHS, MSA
Juniper SFP-1GE-LX
1.37 cm
5.66 cm
1.25 cm
28 g
Limited warranty - lifetime
70 °C
5 - 95%
B3GZ StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.24
B3GZ StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.64
B3GZ StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £17.89
B3GZ StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.85
B3GZ StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £149.00
B3GZ StarTech.com Fiber Media Converter - Open In Stock £44.55
B3GZ StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £338.20
Type: Modules
