1000 Pack Medium 6" 152.4 mm White Nylon 66 |94V-2 Fire & UL Rated TAA UL. These Medium cable ties enable you to conveniently bundle and secure multiple cables, to route and organize them. 1000 White cable ties are included, ensuring you'll have plenty on hand.
Keep Cables Organized
These plastic electrical cable wraps are 6" (152.4 mm) in length securing cable bundles up to 1.4" (35.6 mm) in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigourously tested to support up to 40 lbs 18.1 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths and Colors
To suit any application, StarTech.com offers a wide selection of these cable ties in different lengths and colors:
100 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4B)
100 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4N)
1000 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4BK)
1000 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4NK)
100 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6B)
100 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6N)
1000 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6BK)
1000 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6NK)
100 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8B)
100 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8N)
1000 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8BK)
1000 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8NK)
100 Pack - 10" (254 mm) Black Cable Ties (CBMZT10B)
100 Pack - 10" (254 mm) White Cable Ties (CBMZT10N)
1000 Pack - 10" (254 mm) Black Cable Ties (CBMZT10BK)
1000 Pack - 10" (254 mm) White Cable Ties (CBMZT10NK)
These cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Reduce clutter
Easy to install, tighten and see, these plastic electrical cable wraps are ideal for reorganizing your workstation at home or office. -
Keep cables organized
These plastic electrical cable wraps are quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation. -
Industrial strength
Made of durable nylon 66 material, these cable ties are tough and flexible.
- StarTech.com 15cm(6") Cable Ties, 3mm(1/8") wide, 39mm(1-3/8") Bundle Diameter, 18kg(40lb) Tensile Strength, Nylon Self Locking Zip Ties w/ Curved Tip, 94V-2/UL Listed, 1000 Pack, White - Nylon 66 Plastic - TAA (CBMZT6NK) - cable tie - TAA Compliant
- Product Type
- Cable tie
- Packaged Quantity
- 1000 (specifications are for single item)
- 0.4 cm
- Thickness
- 1 mm
- Length
- 15.24 cm
- 0.5 g
- Product Material
- Nylon 6-6
- White
- TAA Compliant
- 2-year warranty
- Packaged Quantity
- Product Type
- Cable tie
- Product Material
- Nylon 6-6
- 0.4 cm
- Length
- 15.24 cm
- Thickness
- 1 mm
- 0.5 g
- Enclosure Colour
- White
- 18.1 kg min loop tensile strength, UL 94V-2 Rated, 36 mm bundle diameter
- TAA Compliant
- Shipping Width
- 28 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 464 g
- Limited warranty - 2 years
- -40 °C
- 85 °C
