StarTech.com 1000 Pack 6" Black Cable Ties
Quicklinx: FY2GWS00 Mfr#: CBMZT6BK
Hurry, only 3 left in stock!
£13.26 ex VAT
£15.91 inc VAT
1000 Pack Medium 6" 152.4 mm Black Nylon 66 |94V-2 Fire & UL Rated TAA UL. These Medium cable ties enable you to conveniently bundle and secure multiple cables, to route and organize them. 1000 Black cable ties are included, ensuring you'll have plenty on hand.
Keep Cables Organized
These plastic electrical cable wraps are 6" (152.4 mm) in length securing cable bundles up to 1.4" (35.6 mm) in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigourously tested to support up to 40 lbs 18.1 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths and Colors
To suit any application, StarTech.com offers a wide selection of these cable ties in different lengths and colors:
100 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4B)
100 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4N)
1000 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4BK)
1000 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4NK)
100 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6B)
100 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6N)
1000 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6BK)
1000 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6NK)
100 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8B)
100 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8N)
1000 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8BK)
1000 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8NK)
100 Pack - 10" (254 mm) Black Cable Ties (CBMZT10B)
100 Pack - 10" (254 mm) White Cable Ties (CBMZT10N)
1000 Pack - 10" (254 mm) Black Cable Ties (CBMZT10BK)
1000 Pack - 10" (254 mm) White Cable Ties (CBMZT10NK)
These cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Reduce clutter
    Easy to install, tighten and see, these plastic electrical cable wraps are ideal for reorganizing your workstation at home or office.
  • Keep cables organized
    These plastic electrical cable wraps are quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
  • Industrial strength
    Made of durable nylon 66 material, these cable ties are tough and flexible.
StarTech.com 15cm(6") Cable Ties, 3mm(1/8") wide, 39mm(1-3/8") Bundle Diameter, 18kg(40lb) Tensile Strength, Nylon Self Locking Zip Ties w/ Curved Tip, 94V-2/UL Listed, 1000 Pack, Black - Nylon 66 Plastic - TAA (CBMZT6BK) - cable tie - TAA Compliant
Cable tie
Packaged Quantity
1000 (specifications are for single item)
0.4 cm
Thickness
1 mm
Length
15.24 cm
0.7 g
Product Material
Nylon 6-6
TAA Compliant
Packaged Quantity
Cable tie
Product Material
Nylon 6-6
0.4 cm
Length
15.24 cm
Thickness
1 mm
0.7 g
Enclosure Colour
18.1 kg min loop tensile strength, UL 94V-2 Rated, 36 mm bundle diameter
TAA Compliant
Shipping Width
26 cm
Shipping Depth
11.5 cm
Shipping Height
1 cm
Shipping Weight
739.1 g
-40 °C
85 °C
FY2G StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small In Stock £6.64
FY2G StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large In Stock £8.29
