Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40km over Single Mode LC fiber. The ET1000S40LC2 1000 Mbps Gigabit Single-Mode Fiber Media Converter (LC, 40 km) enables you to extend a Gigabit Ethernet network over single-mode fiber, at distances up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Versatile connectivity options
Includes LC single-mode and RJ-45 connectors for flexible integration into diverse networking environments. -
Robust environmental resilience
Designed to operate within a temperature range of 0°C to 60°C, supporting a humidity range of 10 to 90%, ensuring reliability in various conditions. -
High data transfer efficiency
Achieves a data transfer rate of 1 Gbps, suitable for fast-paced networking needs. -
Extended operating distance
Enables communication over distances of up to 40 km, ideal for large installations. -
Simple integration
Compliant with Plug-and-Play standards, allowing for quick and straightforward setup without additional configuration.
- StarTech.com 1000 Mbps Gigabit Single-Mode Copper to Fiber Media Converter - Ethernet (1000Base-T) to LC Fiber Converter (ET1000S40LC2) - fibre media converter - 1GbE
- Fibre media converter - RJ-45 / LC single-mode
- Form Factor
- External
- Localisation
- North America, United Kingdom, Europe
- Cabling Type
- 1000Base-LX, 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 40 km
- Power
- AC 120/230 V
- 9.5 cm x 16 cm x 2 cm
- 0.62 kg
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Form Factor
- External
- Black
- Localisation
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 1310 nm
- 40 km
- Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC single-mode female x 2
- MTBF
- 65,000 hours
- Plug and Play, FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- 9.5 cm
- 16 cm
- 2 cm
- 0.62 kg
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
- Designed For
StarTech.com Fiber Media Converter - w/ SFP | In Stock | £67.70 |
StarTech.com GbE Fiber Media Converter 10km | In Stock | £183.62 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
