StarTech.com 1000 Mbps Gigabit Single Mode Fiber Media Converter LC 40 km
Quicklinx: 85DCWS00 Mfr#: ET1000S40LC2
Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40km over Single Mode LC fiber. The ET1000S40LC2 1000 Mbps Gigabit Single-Mode Fiber Media Converter (LC, 40 km) enables you to extend a Gigabit Ethernet network over single-mode fiber, at distances up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to LC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
  • Versatile connectivity options
    Includes LC single-mode and RJ-45 connectors for flexible integration into diverse networking environments.
  • Robust environmental resilience
    Designed to operate within a temperature range of 0°C to 60°C, supporting a humidity range of 10 to 90%, ensuring reliability in various conditions.
  • High data transfer efficiency
    Achieves a data transfer rate of 1 Gbps, suitable for fast-paced networking needs.
  • Extended operating distance
    Enables communication over distances of up to 40 km, ideal for large installations.
  • Simple integration
    Compliant with Plug-and-Play standards, allowing for quick and straightforward setup without additional configuration.
StarTech.com 1000 Mbps Gigabit Single-Mode Copper to Fiber Media Converter - Ethernet (1000Base-T) to LC Fiber Converter (ET1000S40LC2) - fibre media converter - 1GbE
Fibre media converter - RJ-45 / LC single-mode
External
North America, United Kingdom, Europe
Cabling Type
1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
40 km
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.62 kg
P/N: SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
40 km
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-LX/1000Base-SX - LC single-mode female x 2
MTBF
65,000 hours
Plug and Play, FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.62 kg
60 °C
10 - 90% (non-condensing)
85DC StarTech.com Fiber Media Converter - w/ SFP In Stock £67.70
85DC StarTech.com GbE Fiber Media Converter 10km In Stock £183.62
85DC StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
85DC StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
