Make reliable Ethernet connections in applications requiring CMR-rated cable. The WIRC5ECMRGRY Cat5e 350MHz Solid UTP Cable (Gray) is CMR rated for use in walls, conduit, ceilings, etc. and is packaged as a 1000-foot bulk roll. The cable features a gray PVC jacket, which provides both flexibility and durability, while making it easier to color code network cable connections.
- StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable - RJ45 Patch Cable - Cat 5e Patch Cable - Cat5e Patch Cable (WIRC5ECMRGRY) - bulk cable - 304.8 m - grey
- Bulk cable - CAT 5e
- Technology
- Wires per Cable
- 8 wires
- Solid
- Length
- 304.8 m
- Grey
- Limited lifetime warranty
- Designed For
- P/N: ST121HDWP, STUTPWALLA, USB110EXT2
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Solid
- Length
- 304.8 m
- Grey
- RoHS, NEC-CMR - up to 350 MHz
- Designed For
StarTech.com RJ45 RJ11 Crimp Tool with Cable Stripper | In Stock | £29.83 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £206.76 |
