These RJ-45 dust covers install in any standard RJ45/LAN slot, keeping the open ports on your device safe from dust and debris.
Protect your network equipment
These RJ45 dust covers install in any standard RJ45/LAN slot keeping the open ports on your switches, routers, network cards and media converters safe from dust and debris. -
Avoid network issues caused by dust
RJ45 dust caps prevent network errors and potential downtime caused by dust and debris in open slots. -
Easy to install and remove
With a convenient outward facing pull-tab, these snap-in Ethernet port protectors are easy to insert and remove without disrupting adjacent ports or cables.
- StarTech.com 100 Pack RJ45 Dust Covers, Reusable RJ45 Blanking Plug/ Dust Cap, Ethernet/LAN Port Protector/ Blocker, Snap In RJ45 Female Jack Protective Cover for Hubs, Switches, Routers - Ethernet Port Cover (RJ45COVER) - dust cover
- Product Type
- Dust cover
- Packaged Quantity
- 100 (specifications are for single item)
- 1.094 cm x 1.4 cm x 2 cm
- 1.6 g
- Product Material
- PVC
- Black
- 2-year warranty
- Packaged Quantity
- Product Type
- Dust cover
- Product Material
- PVC
- 1.094 cm
- 1.4 cm
- 2 cm
- 1.6 g
- Enclosure Colour
- Black
- Compatible Connector Type
- RJ-45
- Shipping Width
- 15 cm
- Shipping Depth
- 18.5 cm
- Shipping Weight
- 184 g
- Limited warranty - 2 years
