StarTech.com 100 RJ45 Dust Covers - RJ45 Blanking Plug - Ethernet/LAN Port Protector/ Blocker
Quicklinx: FYH0WS00 Mfr#: RJ45COVER
30 In Stock
£11.71 ex VAT
£14.05 inc VAT
These RJ-45 dust covers install in any standard RJ45/LAN slot, keeping the open ports on your device safe from dust and debris.
  • Protect your network equipment
    These RJ45 dust covers install in any standard RJ45/LAN slot keeping the open ports on your switches, routers, network cards and media converters safe from dust and debris.
  • Avoid network issues caused by dust
    RJ45 dust caps prevent network errors and potential downtime caused by dust and debris in open slots.
  • Easy to install and remove
    With a convenient outward facing pull-tab, these snap-in Ethernet port protectors are easy to insert and remove without disrupting adjacent ports or cables.
StarTech.com 100 Pack RJ45 Dust Covers, Reusable RJ45 Blanking Plug/ Dust Cap, Ethernet/LAN Port Protector/ Blocker, Snap In RJ45 Female Jack Protective Cover for Hubs, Switches, Routers - Ethernet Port Cover (RJ45COVER) - dust cover
Dust cover
Packaged Quantity
100 (specifications are for single item)
1.094 cm x 1.4 cm x 2 cm
1.6 g
Product Material
PVC
Packaged Quantity
Dust cover
Product Material
PVC
1.094 cm
1.4 cm
2 cm
1.6 g
Enclosure Colour
Compatible Connector Type
RJ-45
Shipping Width
15 cm
Shipping Depth
18.5 cm
Shipping Weight
184 g
FYH0 StarTech.com RJ45 Port Locks - 10 Pack In Stock £6.76
