These high-quality M6 x 12mm screws and cage nuts make it easy to mount equipment in your server rack or cabinet. This 100-pack of M6 mounting screws and cage nuts is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment.
They are also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a nut or two. The bulk package ensures that you have enough available for all your installation needs, when you need them. Both the server rack screws and the nuts come in an all-black finish for a seamless look.
Durable construction
Made from steel, these screws and nuts are built to withstand rigorous use in various environments, ensuring a reliable connection. -
Complete package
This pack provides everything needed for successful installations with 100 screws and 100 cage nuts, making it a solution for hardware mounting.
- StarTech.com M6 x 12mm Screws and Cage Nuts - 100 Pack - M6 Mounting Screws and Cage Nuts for Server Rack and Cabinet - Black (CABSCREWM62B) - rack screws and nuts
- Product Type
- Rack screws and nuts
- Package Content
- 100 M6 cage nuts, 100 M6 screws
- Black
- Product Material
- Steel
- 1.2 cm
- 230 g
- 2-year warranty
- Designed For
- P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
- Product Type
- Product Material
- Steel
- Package Content
- 1.2 cm
- 230 g
- Black
- Limited warranty: - 2 years
- Designed For
- P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMNT12, WALLMOUNT4, WALLMOUNT6, WALLMOUNT8, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks | In Stock | £213.48 |
StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £202.12 |
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks | In Stock | £173.48 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 2-Post Server Rack - 42U | In Stock | £151.52 |
