StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large
Quicklinx: FXZHWS00 Mfr#: CBMCTM3
Hurry, only 2 left in stock!
£8.29 ex VAT
£9.94 inc VAT
100 Pack Work with Cable Ties up to 0.21 in. (5.5 mm) in width Self-Adhesive TAA. These large cable tie mounts with adhesive backing enable you to conveniently mount your zip ties to secure your cable bundle to the wall or ceiling, to route and organize them. 100 White cable tie mounts are included, ensuring you'll have plenty on hand.
Easy to Install and Use
These plastic electrical cable wrap mounts work with cable ties up to 0.21 in. (5.5 mm) in width, at any length.
They're quick and easy to install, simply peel off the protective backing and stick it to your desired location on any surface, including plastic, metal, drywall, wood, or masonry. Once the mount is in place, you can feed the cable tie through the slot, position your cable bundle inside the tie and close the cable tie to secure both the cable bundle and the cable tie to the mount. For added security on heavier cable bundles a built-in mounting hole (5 mm in diameter) enables you further secure the mount with a screw.
This clean and professional cable tie mounting system is perfect for organizing and routing network cables, power cables, or other cables in your office or server room.
Industrial Strength
Made of durable Nylon 66 material and featuring a strong 3M adhesive sticky backing these cable tie mounts are UL94 V-2 fire rated, and UL Approved.
Supported StarTech.com Cable Ties
StarTech.com offers a variety of cable ties that are supported by these mounts:
100 Pack 4 in. (101.6 mm) White Cable Ties (CBMZT4N)
1000 Pack 4 in. (101.6 mm) White Cable Ties (CBMZT4NK)
100 Pack 4 in. (101.6 mm) Black Cable Ties (CBMZT4B)
1000 Pack 4 in. (101.6 mm) Black Cable Ties (CBMZT4BK)
100 Pack 6 in. (152.4 mm) White Cable Ties (CV150)
1000 Pack 6 in. (152.4 mm) White Cable Ties (CV150K)
100 Pack 6 in. (152.4 mm) White Cable Ties (CBMZT6N)
1000 Pack 6 in. (152.4 mm) White Cable Ties (CBMZT6NK)
100 Pack 6 in. (152.4 mm) Black Cable Ties (CBMZT6B)
1000 Pack 6 in. (152.4 mm) Black Cable Ties (CBMZT6BK)
100 Pack of 6 in. (152.4 mm) White Resealable Cable Ties (CBMZTRB6)
100 Pack of 6 in. (152.4 mm) Black Resealable Cable Ties (CBMZTRB6BK)
100 Pack of 8 in. (203.2 mm) White Cable Ties (CBMZT8N)
1000 Pack of 8 in. (203.2 mm) White Cable Ties (CBMZT8NK)
100 Pack of 8 in. (203.2 mm) Black Cable Ties (CBMZT8B)
1000 Pack of 8 in. (203.2 mm) Black Cable Ties (CBMZT8BK)
100 Pack of 8 in. (203.2 mm) Gray Cable Ties (CV200K)
100 Pack of 8 in. (203.2 mm) White Resealable Cable Ties (CBMZTRB8)
100 Pack of 8 in. (203.2 mm) White Resealable Cable Ties (CBMZTRB8BK)
100 Pack of 10 in. (254 mm) White Cable Ties (CBMZT10N)
1000 Pack of 10 in. (254 mm) White Cable Ties (CBMZT10NK)
100 Pack of 10 in. (254 mm) Black Cable Ties (CBMZT10B)
1000 Pack of 10 in. (254 mm) Black Cable Ties (CBMZT10BK)
100 Pack of 10 in. (254 mm) White Resealable Cable Ties (CBMZTRB10)
100 Pack of 10 in. (254 mm) Black Resealable Cable Ties (CBMZTRB10BK)
These cable wrap mounts are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Easy to install and use
    These plastic electrical cable wrap mounts are quick and easy to install, simply peel off the protective backing and stick it to your desired location on any surface, including plastic, metal, drywall, wood, or masonry. Once the mount is in place, you can feed the cable tie through the slot, position your cable bundle inside the tie and close the cable tie to secure both the cable bundle and the cable tie to the mount.
  • Industrial strength
    Made of durable nylon 66 material and featuring a strong adhesive sticky backing.
StarTech.com 100 Pack Cable Tie Mounts with Adhesive Tape for 0.21 in. (5.5 mm) Wide Ties, Nylon/Plastic Zip Tie Mounts, Electrical/Network Cable Wrap Mounts / 94V-2 Fire & UL Rated TAA - Nylon 66 Zip Tie Mount (CBMCTM3) - cable tie mount - TAA Compliant
Cable tie mount
Packaged Quantity
100 (specifications are for single item)
2.7 cm x 2.7 cm x 0.5 cm
1.8 g
Product Material
Nylon 6-6
White
TAA Compliant
StarTech.com 1U Rack Mountable Cable Lacing Bar w/Adjustable Depth, Cable Support Guide For Organized 19" Racks/Cabinets, Horizontal Cable Guide For Patch Panels/Switches/PDUs
Packaged Quantity
Cable tie mount
Product Material
Nylon 6-6
2.7 cm
2.7 cm
0.5 cm
1.8 g
Enclosure Colour
White
Self-adhesive, UL 94V-2 Rated, for cable ties width up to 5.5 mm
TAA Compliant
Shipping Width
18.5 cm
Shipping Depth
23.5 cm
Shipping Weight
193.2 g
FXZH StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small In Stock £6.64
FXZH StarTech.com 100 Pack 10" Black Cable Ties In Stock £7.46
