100 Pack| Self-Adhesive 6 Segment Extinguishing PVC M1 Rated NF Fire Resistant. These self-adhesive multi-segment cable clamps enable you to conveniently secure and route up to six cables to one spot at any workstation. The cables are held in place by their connector ends and can then be pulled through the clip so you can easily connect them to your devices. Then, if you disconnect your device you can rest assured the cables will stay in place for the next time you connect your device. 100 black cable clips are included, ensuring you'll have plenty on hand for mass deployment.
Easy to Install and Use
The with an adhesive backing, the cable clamp can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including plastic, metal, wood, or glass.
Once installed the clamps can hold up to six cables, each in individual cable slots, providing an ideal solution to organize cables at your workstation and reduce cable clutter, while also preventing cables from falling off your desk. The clamp is equipped with a clip that opens, making it easy to change or rearrange the cables or wires that are contained within it.
Industrial Design for Reliability and Safety
The 6 segment cable clamp is made of a durable nylon 66 material, and features a strong 3M adhesive sticky backing with a versatile one piece design. The cable holders are also UL94 V-2 fire rated and UL approved to ensure they're safe for industrial use.
These cable clamps are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Versatile one-piece design
Clamp opens up making it easy to change cables; great for charging cables, power cables, USB cables, docking cables, audio, video, network and data cables. -
Easy to install and use
The with an adhesive backing, the cable clamp can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including plastic, metal, wood, or glass. Once installed the clamps can hold up to six cables, each in individual cable slots, providing an ideal solution to organize cables at your workstation and reduce cable clutter, while also preventing cables from falling off your desk. The clamp is equipped with a clip that opens, making it easy to change or rearrange the cables or wires that are contained within it. -
Industrial design for reliability and safety
The 6-segment cable clamp is made of a durable nylon 66 material, and features a strong adhesive sticky backing with a versatile one-piece design. The cable holders are also UL94 V-2 fire-rated and UL approved to ensure they're safe for industrial use.
- StarTech.com 100 Pack Cable Management Clips, Self Adhesive 6 Slot Cable Comb, Resusable Desktop USB/Computer/Ethernet/AV Cord Organizer/Sticky Cable Holders, Nylon 66 Cable Clamp UL Rated - UL94 V2, M1 Fire Rated (CDM6SCC) - cable management clip - TAA Compliant
- Product Type
- Cable management clip
- Packaged Quantity
- 100 (specifications are for single item)
- 2.174 cm x 9.691 cm x 1.419 cm
- 8 g
- Product Material
- Nylon 6-6
- Black
- TAA Compliant
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Nylon 6-6
- 2.174 cm
- 9.691 cm
- 1.419 cm
- 8 g
- Enclosure Colour
- Black
- Self-adhesive, 6 slots, UL rated, M1 Rated NF Fire Resistant, 9.2 mm - 14.9 mm bundle diameter
- TAA Compliant
- Shipping Width
- 26.5 cm
- Shipping Depth
- 38 cm
- Shipping Height
- 9 cm
- Shipping Weight
- 800 g
- Limited warranty - 2 years
