StarTech.com 100 Pack of Screw Down Cable Clamps - Medium
Quicklinx: FY04WS00 Mfr#: CBMSDCC2
£5.81 ex VAT
£6.97 inc VAT
100 Pack Medium Screw Down TAA. These R type cable clips secure cables to the wall to route and organize them. 100 White cable clips are included, ensuring you'll have plenty on hand.
Secure Your Cables with an R- Type Cable Clip
These plastic electrical cable clips feature a built-in 0.18 in. (4.6 mm) mounting hole enabling you to bundle cables while mounting them to a wall. They hold medium cables up to 0.25 in. (6.35 mm). They're quick and easy to install or remove, with a single screw hole that secures the cable and mounts it to the wall - perfect for organizing and routing network cables, power cables, or other cables at your home or office.
Industrial Strength
Made of durable Nylon 66 material, these cable clips are tough and flexible. They're -40 to 85C temperature rated, UL94 V-2 fire rated, UL Approved.
Available in Different Sizes
To suit different applications, StarTech.com offers a selection of these cable clips in different sizes:
Small for 0.19in (5 mm) cable diameter (CBMSDNMCC1)
Medium for 0.25in (6.35 mm) cable diameter (CBMSDNMCC2)
Large for 0.31in (7.9 mm) cable diameter (CBMSDNMCC3)
These cable clips are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Organize and secure
    Cable management fastener to mount coax, RJ11 telephone wire, AV, RJ45 CAT5/CAT6 Ethernet, network and USB cables to baseboards, wood trim, drywall or masonry with single screw or nail.
  • Secure your cables with an R-type cable clip
    These plastic electrical cable clips feature a built-in mounting hole enabling you to bundle cables while mounting them to a wall. They're quick and easy to install or remove, with a single screw hole that secures the cable and mounts it to the wall - perfect for organizing and routing network cables, power cables, or other cables at your home or office.
  • Industrial strength
    Made of durable nylon 66 material, these cable clips are tough and flexible.
StarTech.com 100 Pack Screw Mount Cable Clamps, Medium 6.35mm Bundle Cable Fastener/Holder, R-Type Single Reusable Nylon Clip, Screw Down Ethernet Cord Management Clamp, UL/94V-2 Rated TAA - Nylon 66 Plastic - TAA (CBMSDCC2) - cable organizer clamp - TAA Compliant
Cable organizer clamp
Packaged Quantity
100 (specifications are for single item)
2 cm x 0.7 cm x 1 cm
0.5 g
Product Material
Nylon 6-6
White
TAA Compliant
Packaged Quantity
Product Material
Nylon 6-6
2 cm
0.7 cm
1 cm
0.5 g
Enclosure Colour
White
UL 94V-2 Rated, for cable diameter 6.35 mm
TAA Compliant
Shipping Width
11.5 cm
Shipping Depth
16 cm
Shipping Height
1 cm
Shipping Weight
52 g
-40 °C
85 °C
